Bog?
Discussion in 'The Garage' started by shaun, May 17, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Can anyone explain this to me. I entered the mudbogs this weekend and was quite impressed with my truck. Would have one the stock class but I lost to a scout on 38's with a built 350. Cool huh. The only problem I have is when I floor it off the line it bogged down and I never actually got to go until every truck was a whole truck lengths ahead of me. What would cause me to bog down. It didnt matter what gear. I have 198,287 miles on my stock tbi 350. 33's and 5 inches lift. 4.11's in the rear 14 bolt and 3.73's in the front 6 lug 10 bolt (hadnt finished the 3/4 ton swap yet). I tried it in OD, D, 2 and first and I bogged in all. Why? /forums/images/graemlins/dunno.gif
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    High range or low range?
  3. shaun
    Apr 22, 2003
    745
    Low range.
  4. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    you need more power.
  5. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    You might want to try stalling your converter out when you launch, stand on the brakes and rev it up in gear until just before the wheels start to spin /forums/images/graemlins/thumb.gif and of course more power wouldn't hurt either /forums/images/graemlins/peace.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If your engine is bogging in low gear, it's probably not running right. I'd bet your timing is slow or you have a vacuum leak or something.
  7. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    I have a question, are you sure you were bogging down or just spinning the tires? Do you have a tack that you could look at to see if you are in fact spinning the tires before hooking up in the mud or in fact bogging down? If you are bogging down, then you can either try to tune up your engine to try to get more power out of it, or air up your tires more then normal. by airing up your tires, it will make it loose some grip and might get you out of the hole without bogging.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It was bogging the enigine just wound up slow until it hit about 1500-1800 RPM's then you could hear it start going /forums/images/graemlins/waytogo.gif
  9. sr175
    sr175 Registered Member
    Mar 31, 2004
    76
    Tracy, CA
    check timing, you have a little gear mismatch there and more power /forums/images/graemlins/peace.gif. Could try a cam thats better for that rpm range or the many other upgrades you could do. /forums/images/graemlins/whistling.gif
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I tried it in OD
    Just something small but NEVER use OD offroad where there is a big load on the tranny. OD is for puting down the highway at 55mph+.
    I would just say your motor is tired and lean on power. My old 350 did the same kind of stuff when it was still in.
  11. shaun
    Apr 22, 2003
    745
    slimlynn1 : [you need more power.]
    I know. I ggot a little over 198,000 on the original 350 it will get a 454 at the end of the summer
    johnc : [You might want to try stalling your converter out when you launch, stand on the brakes and rev it up in gear until just before the wheels start to spin and of course more power wouldn't hurt either ]
    I thought about that but in 1rst and low everytime I touched the gas the whole truck tweeked and I didnt want to push my self over the line (my rear seem to hold a little better than my front) because then I would be disqualified
    84 chevy k10 : [If your engine is bogging in low gear, it's probably not running right. I'd bet your timing is slow or you have a vacuum leak or something.]
    That is what I originally thought too but after my first two runs we checked everything and she was running great. My timing was actually advanced so I am not sure.
    Hustler : [I have a question, are you sure you were bogging down or just spinning the tires? Do you have a tack that you could look at to see if you are in fact spinning the tires before hooking up in the mud or in fact bogging down? If you are bogging down, then you can either try to tune up your engine to try to get more power out of it, or air up your tires more then normal. by airing up your tires, it will make it loose some grip and might get you out of the hole without bogging]
    I am sure I was bogging. mtblazer 89 has the same problem sometimes. My tires were at 33 psi and I was bogging off the line when floored no where else. I cant really tune up the engine anymore without a cam or heads. It is getting headers here shortly and I am going to put a 454 tb plenum on it to see if that will liven it up. Once again 198,00 it is kinda pass the tune up stage, but it has all new ignition components (msd), new plugs and wires, rebuilt tb with all new sensors (in the last 2 months).
    mtblazer89 : [It was bogging the enigine just wound up slow until it hit about 1500-1800 RPM's then you could hear it start going]
    Exactly. I need to build that 454
    sr175 : [check timing, you have a little gear mismatch there and more power . Could try a cam thats better for that rpm range or the many other upgrades you could do.]
    Timing was good but I am going to look into the cam.
    rjfguitar ; [Just something small but NEVER use OD offroad where there is a big load on the tranny. OD is for puting down the highway at 55mph+.
    I would just say your motor is tired and lean on power. My old 350 did the same kind of stuff when it was still in.]
    I know I drove it from home got there and did my practice run right away. So forgot to run it 1rst or 2nd. Learned that lesson real quick.
    Thanks for the help anymore ideas. /forums/images/graemlins/k5.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If your engine is running correct and bogging down in the mud, you need more power.
    I don't think it's running right though.
  13. shaun
    Apr 22, 2003
    745
    Its not bogging down in the mud. It is doing it at the launch. Its like I floor it and a second later it goes.
    example.
    hit peddle
    vrrrr (slow)
    then after a second or so it goes
    waaaaaaaa (fast)
    I dont know if I am describing it well. But it does great once it gets moving it just hesitates right off the line. /forums/images/graemlins/dunno.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Change your fuel filter.
  15. shaun
    Apr 22, 2003
    745
    I will give that a shot. For my owqn knowledge why would that cause it to bog or hesitate only when I floor it from a stop? I dont understand.
  16. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    mine sometimes does this, and on mine its a carburator issue. I think the accelerator pump is too larg and im running it rich on takeoff. Thus the reason that it bogs (bulb bulb bulb braaaaaaaa) for a bit, then gets to gettin. But i havn't looked into it any further.
    good luck though. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  17. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Off Idle bog is a fairly common problem with TBI. Try setting your TPS up to .70 volts. That will richen up the mixture off idle a bit.
    Also an adjustable fuel pressure regulator set to around 14 PSI will help too.
    Wish I would have heard about Mud Bogs at Fallon. prolly would have made a little trip down there to see them. Maby made a run or 2 myself. Where did they have them?
  18. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    [/ QUOTE ] My question is why are you running two different gear sizes? Won't that break something? Maybe a t-case.
  19. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    They have them up at the dirt track. The next ones are like Aug 7th or they have them this coming weekend in Fernley I believe. Maybe come out for the one at the end of the summer. /forums/images/graemlins/waytogo.gif
    Race track page
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Because that's when you have a major transition in necessary fuel flow.
    Usually it'd die off at high RPM too, cough, sputter, etc.
