Bogging down a LOT...can barely get to 15 mph...
Discussion in 'The Garage' started by Lotsa_Faith, Jun 24, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    i am running out of ideas now...it just started doing this...the only thing i changed was installed a cd player, which shouldnt make any kind of difference on the engine...what do you think? its not the fuel filter, and i have the choke wired open...
  2. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    anyone know what could be the problem?
  3. dyeager535
    26,982
    191
    It being a 1009, no chance you swapped in a cat converter?
  4. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    nope no cats. I'm getting frustrated with dealing with this engine... as soon as you get one thing fixed, the next thing pops up...anybody got a great running 350 for about $140.75?
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Everything have oil?
    Checked the timing?
    Could the muffler be plugged?
    Parking brake releasing?
  6. dyeager535
    26,982
    191
    And disconnecting the radio doesn't make a difference?
  7. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    everything has oil, haven't checked timing but i dunno why it would all of the sudden become that far off, lol no mufflers to be plugged, and parking brake released...
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Could you be more specific? Is the problem at startup? Or only when you give it gas? Does it occur at idle? at Wide open? Hot? cold? Gimme a run down, sounds like something with the iginition, sounds like crappy wire/crapped out distributor.
  9. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    ok here goes...
    its occured after startup when its not really warm, but it also happened tonight after it was plenty warm. It seems to come around 30 mph or less, no matter if its wide open or pugging it at slow as it will go. i'm thinking fuel pump, but being the scrounging teen that i am, i dont wanna spend money on something i dont need.
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    could be the fuel pump, but I dont think its your problem here. I think your probably having a spark short of some sort, one of the plugs, or several of them arent getting enough. You can have a buddy mash the gas while you look down the choke, to see if it is getting enough gas. If it still runs kinda crappy, check to make sure to see that every plug wire is in tight, and also not touching any part of the engine which could melt it (manifolds) or short it because it got partly cut or melted. Easiest way to see it is to start the engine, and then open the hood (at night) and see if you see any sparks flying around.
    Hope this helps...
