bogging down and running real rich
Discussion in 'The Garage' started by chvymudin3388, Jan 22, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    what could be causing this? its got new cap, coil, rotor, and pick up coil.
  2. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Is it carbed or injected? If the former, what kind of carb?
    Check your float level.
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    its tbi 87
  4. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Reset the ECM (disconnect power for a while), then see if it's throwing any codes while running. If it's as bad as you say, then it should be.
    Could be an O2 sensor, bad coolant temp sensor, etc.
  5. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well its not the O2 sensor and im trying te TPS next
  6. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    if O2 is fine, backprobe the tps through its full range of motion, checking for unusual readings, like voltage spikes, flat spots, or out-of-range message. then, make sure the MAP sensor has all of it's tubes and wires connected. if that's fine, i'd check the IAC and make sure that the piston moves freely. those aren't the only things to check, but they're easy.
  7. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    where is the MAP sensor anyway im not very familiar where everything is i am with most things
  8. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    pop the air cleaner off, and look at the manifold area. the MAP is generally (from what i've seen on gm trucks) located on the passenger side of the intake manifold, on a bracket, several inches from the throttle body. it's a small box, only a few inches long, and should have wires and vac tubes running to it.
    i had a hose slip loose, a few years ago, and it ran pretty rough. replaced it with fuel line since it was getting crusty anyway.
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well try it but please keep the suggestions coming
  10. Aquaholic
    Aquaholic Registered Member
    Jan 19, 2007
    6
    Texas
    I have an 87 and am having the same problem. Have you had any luck?
  11. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well i just found out my problem my freshly rebuilt 3,000 mile motor has real bad blow by issues and is dumping oil into the tbi from the breather tubes runningt o the tbi from teh valve covers
