bogging down on corners
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Dec 21, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Just started today, when I was going around a corner and giving it gas, the engine would bog down. It has an edalbrock 1406 600 cfm carb, everything else involving the fuel system is stock. Any ideas?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My '92 truck does that when I'm almost out of gas.
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Fuel level in the float bowl would be my guess.
    Does it do it if you open the secondaries on a straightaway for extended periods of time?
  4. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    i usually try to stay away from the secondaries, gas is expensive, but it has been running fine on the freeways, this just started and its only when im cornering and giving it gas
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sounds good to me. Sometimes those floats can ger saturated with gas over time and they will start to drop down. You can buy brass floats. Or just get the rebuild kit that should come with a new float.
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    By using the secondaries we know if your float bowl is getting sucked dry. The only time the secondaries are used is when you get past the 2/3 throttle mark. You can feel it in the pedal. Under normal driving, the seconaries never open.
  7. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    Most of the rebuild kits I've picked up, ok it's only been three, haven't came with a float, had to purchase that seperately, though if your takeing it apart to replace the float may as well kit it also.
