Bolt Grade Comparo?
Discussion in 'The Garage' started by Hossbaby50, May 31, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Anyone have a link to a website with numbers on the strengths of the different Grade bolts? I need the numbers for Grade 5,8,10 of the 9/16" and 5/8" sizes
    Anyone know of a site or the strengths of studs? I need to figure out what I am going to do with my sheared steering studs.
    1" extended over stock 9/16" steering studs apparently aren't that tough. I need to get something tougher. Thanks
    Harley
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Ya try pirate yet? /forums/images/graemlins/thinking.gif
    http://www.pirate4x4.com/tech/billavista/TechReference/index.html
    Bolt Size 18-8 Stainless Steel Brass Aluminum 2024-T4 316 Stainless Steel Nylon
    2 - 56 2.5 2.0 1.4 2.6 0.44
    4 - 40 5.2 4.3 2.9 5.5 1.19
    4 - 48 6.6 5.4 3.6 6.9
    6 - 32 9.6 7.9 5.3 10.1 2.14
    6 - 40 12.1 9.9 6.6 12.7
    8 - 32 19.8 16.2 10.8 20.7 4.30
    8 - 36 22.0 18.0 12.0 23.0
    10 - 24 22.8 18.6 13.8 23.8 6.61
    10 - 32 31.7 25.9 19.2 33.1 8.20
    1/4" - 20 75.2 61.5 45.6 78.8 16.00
    1/4" - 28 94.0 77.0 57.0 99.0 20.80
    5/16" - 18 132.0 107.0 80.0 138.0 34.90
    5/16" - 24 142.0 116.0 86.0 147.0
    3/8" - 16 236.0 192.0 143.0 247.0
    3-8" - 24 259.0 212.0 157.0 271.0
    7/16" - 14 376.0 317.0 228.0 393.0
    7/16" - 20 400.0 357.0 242.0 418.0
    1/2" - 13 517.0 422.0 313.0 542.0
    1/2" - 20 541.0 443.0 328.0 565.0
    9/16" - 12 682.0 558.0 413.0 713.0
    9/16" - 18 752.0 615.0 456.0 787.0
    5/8" - 11 1110.0 907.0 715.0 1160.0
    5/8" - 18 1244.0 1016.0 798.0 1301.0
    3/4" - 10 1530.0 1249.0 980.0 1582.0
    3/4" - 16 1490.0 1220.0 958.0 1558.0
    7/8" - 9 2328.0 1905.0 1495.0 2430.0
    7/8" - 14 2318.0 1895.0 1490.0 2420.0
    1" - 8 3440.0 2815.0 2205.0 3595.0
    1"- 14 3110.0 2545.0 1995.0 3250.0
    Torque Values = FT - lbs
    Bolt Size Inches Coarse Thread/ inch SAE 0-1-2 74,000 psi Low Carbon Steel SAE Grade 3 100,000 psi Med Carbon Steel SAE Grade 5 120,000 psi Med. Carbon Heat T. Steel SAE Grade 6 133,000 psi Med. Carbon Temp. Steel SAE Grade 7 133,000 psi Med. Carbon Alloy Steel SAE Grade 8 150,000 psi Med Carbon Alloy Steel
    1/4 20 6 9 10 12.5 13 14
    5/16 18 12 17 19 24 25 29
    3/8 16 20 30 33 43 44 47
    7/16 14 32 47 54 69 71 78
    1/2 13 47 69 78 106 110 119
    9/16 12 69 103 114 150 154 169
    5/8 11 96 145 154 209 215 230
    3/4 10 155 234 257 350 360 380
    7/8 9 206 372 382 550 570 600
    1 8 310 551 587 825 840 700
    1-1/8 7 480 872 794 1304 1325 1430
    1-1/4 7 375 1211 1105 1815 1825 1975
    1-3/8 6 900 1624 1500 2434 2500 2650
    1-1/2 6 1100 1943 1775 2913 3000 3200
    1-5/8 5.5 1470 2660 2425 3985 4000 4400
    1-3/4 5 1900 3463 3150 5189 5300 5650
    1-7/8 5 2360 4695 4200 6980 7000 7600
    2 4.5 2750 5427 4550 7491 7500 8200
    I can't copy this stuff very well, but there are a couple of spec. charts on there. I saw a class 10 listed but no grade 10
    bob
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    How about the ARP studs ORD is now offering?
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't think the ARP studs are out for the D44 crossover yet. I put up a post in there forum to see on availbility. Thanks
    Harley
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    bob
    Me too, was so curious I did a search and found lots of these :
    Chart I found 1
    Chart I found 2
    Lots of info out there, I even read where since the 80's there are many low grade knockoffs out there , so always buy bolts from reputable source. /forums/images/graemlins/k5.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    6 points hardware has tons of books on that. If you catch them on a slow day they will help you look up stuff for hours.
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    The Machinery's Handbook has all of this info and more. It contains information about every type of mechanical component, fastener, material and everything else. It is an invaluable tool to have. They sell them at Barne's and Noble.
    -Chris
