Bolt head loading on Rock stomper bead locks?
Discussion in 'The Garage' started by cybrfire, Jan 2, 2003.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Has anyone had a problem with this? Why not put a spacer between the two rings to keep the lock ring from coning in when torqued? I'm just about to order one and check it out was curious if anybody else had problems with that uneven head loading.
  2. Storm Trooper
    Nov 24, 2000
    4,640
    I don't know about Rock Stompers but my trail ready's are onlt torqued to 10 lbs. How much do the stompers require?
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    10-20 lbs. torque. Not enough to break a bolt head off but, Are yours loading evenly on the head?
  4. Storm Trooper
    Nov 24, 2000
    4,640
    No, but mine are only at 10 LBS. and there is a lot of them on each wheel. You can compare rims by looking at my pictures here -
    Beadlock mounting
    Maybe the stompers have less bolts?
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Thanks for the pics of the install. Those look great!
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have a set of beadlocks which I designed off the rockstomper design. I had a fabricator build mine after I drew them in AutoCAD. Mine have 32 Bolts which are 3/8" and countersunk. Countersinking gets rid of the problems addressed by having the inner portion of the bolt head with less pressure than the outer portion because of coning. You could use a v-belt to counter the coning effect a little. My beadlocks are similar to the Rockstomper by having a wider ring. They did cone, but Im not worried about it. I didn't use v-belts or anything. Torqued to 20 ft/lbs. It will take you several trips around the rim with the torque wrench with any beadlock you buy. They almost never hold their torque after you tighten the adjacent bolts. I used nutserts for my application - I didnt want to hold a wrench on the backside of each bolt while I torqued them.
    I think the Rockstomper design is the shnitz. Show me any other rim this versitle. If you have problems with the beadlock, just roll the bead onto the original bead and drive home! /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif
  7. Grim-Reaper
    7,385
    Atlanta
    So on the rock stompers you don't cut off the old lip? How is the inner ring attached to the rim?
    Is this a kit that they sell?
  8. Mudzer
    3,639
    Missouri
    Yes, the rockstompers do not require you to remove the old bead ring. You just center the rockstomper inner ring by the outer diameter of your rim and weld it into place. Very simple.
  9. Grim-Reaper
    7,385
    Atlanta
    How much $?
    How much does it widen the wheel? My guess is I need to go down to a 8 inch rim and then after the ring is added I would be like a 9 inch rim?
  10. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I just talked to a guy at Rock stomper and he reassured me that the coning effect is nothing to worry about. All bead locks will cone to some effect. If they don't cone in at all then there probably isn't enough preload on the bead of the tire. LEAK>>> I guess when they were testing them they filled there 44" swamper to 45 lbs. until it leaked and dropped to 40 lbs. and then stopped. Thanks for all your help guys. I'm gona buy a set.
  11. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Yep, it would be about a 9 inch wheel after the beadlock. Go here for more info.
    BIGJ
