Bolt on lower shock mounts for 14BFF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k10sub, Feb 26, 2003.
  1. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    These pics are of some home made shock mounts for the M1008 I am working on. I used the old stock spring plates and the old shock mounts I cut off the axle. I know I am giving up some shock travel by mounting this way but I did not want to weld on the axle tubes at this time. Also, I was trying to do this on the "cheap". My cost for the u-bolts came to about $33 from Tulsa Auto Spring because I just didn't have anything on hand in the scrap pile that would work. Another idea was to cut the old spring plates in half and use one u-bolt. I decided against this when I realized the u-bolt would have to come off any time the shock needed to be taken off. Maybe not a big deal either! /forums/images/graemlins/truck.gif
  2. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    different and well done, I like it, now go test it out and let us know how ya like them /forums/images/graemlins/ears.gif
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Look for the shock mounts from F350 Fords.they clamp on and work really well too.I'll take a pic of mine and post. /forums/images/graemlins/thumb.gif
  4. 73k10sub
    Jul 23, 2001
    223
    Tulsa, OK
    Reply to:
    It will be a while. I am still working on the upper mount and am trying to put something together using angle iron and plate. I still don't have the engine back from the shop; the WTO hydro assist installed; fuel system worked out; etc. A lot of work to do. I am thankful for this site, the wealth of info available, and the help from members and non-members alike. /forums/images/graemlins/truck.gif
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    check out howlin offroad's rear shock mount kit. i have it installed on my suburban. there are pics of the upper and lower mounts in my webshots. /forums/images/graemlins/thumb.gif
  6. supersize75
    Sep 27, 2002
    2,638
    this site is my insperation and guide line for my blazer as well, /forums/images/graemlins/grin.gif
  7. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    Why spend the $33 and not just weld the tab to the axle, it woulda taken just as much work either way. I guess I just don't get the point of bolt on that requires welding instead of just a little welding.
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Because not everyone has access to a welder, or knows how to weld, or knows someone who does. But pretty much anyone can bolt an item on.
