Bolt on power for a 91 TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Nov 24, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Is there any mods out there that will give my TBI more hp or torque. All that I have seen are throttle body spacers and people say they arent worth the trouble.
  2. unsane
    unsane Guest
    There are intakes from edelbrock part # 3704 I think, they also have a cam that will work( I know not really bolt on but)also Holley has a throttle body replacement for like $320
  3. dammit32
    Jul 20, 2002
    365
    Maine
    wouldnt you have to reprogram or change the chip in order to get gains?
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    New exhaust and K&N filter! then try the TBI spacer to see if it helps (sometimes it doesn sometimes is doesn't). I used accell street wires and coil, cap and rotor and my /forums/images/graemlins/k5.gif peped up alot. Let it breath and get more fire in the hole! /forums/images/graemlins/thumb.gif
  5. unsane
    unsane Guest
    no , but you could get a hypertech chip though.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Why take the time and effort to bolt something on...just slap some stickers on the windows. /forums/images/graemlins/grin.gif
    Seriously, I have a 90 TBI, and although I can hardly call it "peppy" any longer, the few things I have done, are noticeable. That is: better-flowing dual exhaust, K&N filter, tbi spacer, and better plugs and wires.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    you replied to the wrong guy /forums/images/graemlins/thumb.gif
    I have one of the ads chips and when I installed it, the check engine light come on and it felt like the shift points changed so I pulled it back out. I dont like messing with the (out of the box chips), let someone program your vehicle not your type of vehicle /forums/images/graemlins/deal.gif
    Hows the motor build-up/rebuild going?
  8. bluboti
    bluboti Registered Member
    May 6, 2002
    37
    west virginia --yes-us
    I have a 90 k5 tbi,3" catback, 14" openelement,new plugs etc,but lacks the umph. Only mod that really seems to wake these up is bolting up vortec heads,manifold but pricey.
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    You wouldn't nessaceraly have to re-program the chip most the addon stuff (exhaust, air filter, coil, wires) are designed to go with the vehicle. The chip does not need changed with you change the filter to get more air(your not really super charging it in the way that your forcing more air in, your just freeing it up to pull more air in), or if you add dual exhaust its just breathing better (the computer can see this by the O2 and other TBI sensors and compensate for it). The TBI spacer just helps the fuel atomize better by making the motor think the intake is bigger than it really is. The wires and coil just make hotter spark.
    If you were changing the cam, the intake and the TBI all at once to HI-PO parts, I would diffentanly find a local auto performance place to help you tune the motor(sometimes if you buy the parts from them they will do the intall and tune it /forums/images/graemlins/wink.gif). When you add the cam your changing the intake exhaust points and most aftermarket TBI's are going to flow more air and the intake will change the breathing pattern so I would think its important to get that updated in the computer just to get the most out of it.
    I would start small and if you still not getting the power your wanting you could try the intake and cam (when you do this you also effect the compression a little so its important to think about a ring job and maybe rebuild the heads - this might be where more ponies will come from also depending on the condition on the engine).
    Anyway you go, good luck and post back! Jeremiah
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Supercharger. It's bolt on. /forums/images/graemlins/smile.gif /forums/images/graemlins/rotfl.gif
  11. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Haha, that would do it! Aerocharger used to make a bolt on turbo kit for TBI chevy's designed for torque. The turbo was spooled by 1500 rpms and put out 450 lbs of torque at 2100 rpms!! /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif Thats one hell of an improvement over stock but it also cost $4500... I have a feeling I know why they don't sell em anymore. Turbos off-road are scary though. I've witnessed a turbodiesel hummer sucking water, that wasn't pretty. We found parts of the compressor wheel in the muffler!
  12. dammit32
    Jul 20, 2002
    365
    Maine
    I wanted to get more power from it but I really didnt want to change over to carberation.
    By the way ....We dont have performance shops in Maine...god we're lucky we have gas stations lol
  13. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    thirdgen.org.
    More than you ever wanted to know about modifying your FI 350.
  14. Rootbeer
    Rootbeer Registered Member
    Oct 17, 2002
    10
    Hayward, Ca
  15. dammit32
    Jul 20, 2002
    365
    Maine
    cool site /forums/images/graemlins/laugh.gif
  16. unsane
    unsane Guest
    The motor is built and half way put in... Man its a cold mother out there....NO GARAGE!!! Any way I have to hook everything up and get the rest of the tranny bolts in. The most problems will come from the serpentine sysytem for sure....trying to remember how that goes back together will be a pain in the ass.
  17. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  18. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Perfect solution. Unbolt the 350 and bolt-in a 383. /forums/images/graemlins/thumb.gif
