Bolt on spring swap???
Discussion in 'Suspension | Axle' started by magnum4x4, Apr 24, 2005.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I am checking the interest on a Bolt on 52" front spring swap bracket I made. It is similar to a Jeep shackle reversal for the front, only beefed up a bunch. You can move your front axle foward a few inches with no welding. I am working on a buggy spring set-up for the shackles in the front. Anyway let me know if you intersted.
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    sure... got pics?
  3. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Like topdown said, got pics? What price range are you looking at?
  4. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    Here is a pic of a similar bolt on spring swap. I still have mine on the truck. It is professionally tig welded and made of 1/4" thick steel. I can paint it primer or leave it natural. I am charging $350 and that will include everything including nut, bolts, and washers. All grade 8 hardware. For an extra $25 I can send you longer front shackles to finish of the kit.
  5. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    nice work looks killer.
  6. nvrenuf
    Jan 7, 2002
    13,082
    250
    Mobile, Al.
    What about the body mount?
  7. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    That's what I thought at first glance. "where's the body mounts?"
  8. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    The uprights on the one on my blazer are moved forward almost to the end of the spring cup. It fits between the body mount and the end of the frame.
  9. nvrenuf
    Jan 7, 2002
    13,082
    250
    Mobile, Al.
    Personally, I think the pricing might be a little high. I'd be interested in it right now for $200 if it included the longer rear shackles as well.
    Don't get me wrong I'm not knocking the product, it's a good idea.
    Just a thought, what about maing the spring buckets a little longer with holes for both 52" & 56" springs? :thinking:
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    will it fit a 1st gen?
  11. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    I was even thinking of making a bolt on frame extension with built in spring buckets for 52" springs. Thinking about making my frame about 8" longer in the front.
