bolt on steering brace Q
Discussion in 'OffRoad Design' started by Jonny-K5, Dec 21, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    let me start off by saying this is a great product and every truck should have one. but when i bolted on the steering brace last weekend i ran into a little problem. everything went together fine until i went to tighten down the bolt that goes into the crossmember( the one you drill out). the brace was about a 3/8 inch away from the cross member and took alot of torqueing to get it to lock down. the problem is now my steering wheel is no longer straight. its almost a 1/4 turn to the left as i drive down the road. does this mean my frame was already bent a little before i put it on? the truck has only done light wheeling with 32-33" tires. or did i bent it by putting on the brace. should i have shimmed it up with washers instead of tighening it down? has anyone else had this problem? its no big deal to just adjust the drag link a little , but im wondering if a screwed something up.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Thats funny, I just installed mine today and noticed the same thing /forums/images/graemlins/rotfl.gif About the same spacing and I had to adjust the wheel back. I also noticed most of the bumpsteer is gone and it feels alot firmer. I think it might be me but when I get a few more miles on it i'll be able to tell better.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya mine felt alot firmer too. i dont know if the bumpsteer was changed, but definatly more solid.
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ttt...
  5. 88Silverado
    Mar 13, 2003
    2,664
    Drove mine last nite on a 150 mile drive down the local freeways. The bumpsteer has reduced greatly. Steering feels good. I cant believe the difference it made. /forums/images/graemlins/thumb.gif
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    glad to hear your bumpsteer is better, just wondering, what kind of steering mods did you do for the lift? dropped pitman arm? steering arm?
  7. 88Silverado
    Mar 13, 2003
    2,664
    I went with 4" springs on front so installed a raised steering arm. Did other mods while I was in there (shock towers, lines, disconnects, bushings, etc) After everything is installed I had to adj the draglink to get the steering wheel straight. I did the brace 2 weeks after the lift. I had to readjust the link after installation. I really noticed a difference. Im going to replace the tie rod & draglinks soon and see if that also tightens things up abit.
    Check out the pics on my 88Silverado link above. /forums/images/graemlins/thumb.gif
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Trying to fit anything on a GM frame is tough so it doesnt' surprise me that you had a gap. Stacking 2-3 washers in there would have been my solution but I don't think you're messing anything up by just sucking it down. These frames are pretty loose a lot of the time which is why this system works so well, it just stiffens it all up. It's the little blue pill for the GM frame....
  9. 88Silverado
    Mar 13, 2003
    2,664
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Now theres a great marketing slogan /forums/images/graemlins/rotfl.gif
    The fun part was getting it to fit between the power steering and oil cooler lines /forums/images/graemlins/tongue.gif
    I tightened the three bolts little by little until everything pulled together. Didnt take much force.
    My 88 was owned by a woman. She never wheeled it and its fairly (well...for GM) straight thats why I was so suprised to notice the big improvement. On the other hand, Im not suprised looking at the lack of frame supports /forums/images/graemlins/crazy.gif.
    I am very pleased with your products.
    Worth the investement...Thanks /forums/images/graemlins/thumb.gif
