bolt pattern and size
Discussion in 'The Garage' started by superman6801, Jun 28, 2005.
  1. superman6801
    superman6801 Registered Member
    May 18, 2005
    16
    Denver
    whats the bolt pattern and size for a 73 blazer 2wd?
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    For what? The wheels?
  3. superman6801
    May 18, 2005
    16
    Denver
    yeah. sorry
  4. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    2wd bolt circle...
    73-87 GM 2wd trucks (1/2 ton!) use a 5 lug, 5" bolt circle with 1/2" studs on the wheels...same as most full size GM cars like Caddy's,Impalas,Pontiac Bonneville,Buick Electra's,etc..,also GM 1/2 ton Vans... A few full size Ford and Lincoln Mercury cars use the same pattern as well...backspacing varies on all wheels,so make sure you have clearance all around the tires and disc brake calipers and rotors,and nothing hits or rubs...
    I used tires and rims from my friends 76 Lincoln Continental he was scrapping in the back of my 75 2wd blazer years ago--got a flat in the front,and the lincoln rims and tires I had for spares would not clear the caliper!--that was a long walk home... :mad: it pays to check first in your driveway! :crazy:
  5. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
