bolt pattern...
Discussion in 'The Garage' started by wetbackZO, Oct 10, 2006.
  1. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    hey guys...did the bolt pattern on the blocks change on Vortec engines??
    I'm trying to see if an engine out of a 99 Suburban will mate w/ and older 4L60, anyone know...???
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Yes it will mate up perfectly. The bolt pattern did not change.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The bellhousing pattern stayed the same. However the new engines are mission one of the bolt holes for the transmission bell. I have not heard of any ill effects of this bolt not being used.
    Ira
  4. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    thanx for the prompt reply...highly appreciated...
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You're thinking of the LS1 engine and not the Vortec engine. The only thing that changed with the Vortec engine starting in 1996 were the heads and intake.
  6. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    those ls series need adaptors for new to old motor mounts.
  7. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    mounts will be fabbed, this ain't going in a Chevy, BTW...
  8. sandawgk5
    Oct 28, 2003
    6,881
    Oops I thought that is what he was referring to as in the 6.0 Vortec motor:doah:. Either way the bellhousing pattern did not change:D.
    Ira
