Bolt Size for Springs
Discussion in 'The Garage' started by 79Stomper, Apr 22, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    A question. What size bolts, ie length. thread, and diameter, do i need to replace the ones currently on my truck? New kit didn't come with any and want to get some more with the poly lock nuts to put on when I start the lift tomorrow. Thanks
    JIMBO
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    what springs and what bushings?
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Just need the bolt sizes for the springs. Stock replacement I would guess. It is for the Rough Country 6" lift.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'll pass since mine aren't stock anymore. Mine are now 9/16" and 5/8"
    for stock fronts i think it is 7/16" for the shackle and 1/2" for the front eye 4.5" long.
    rear springs are both 1/2" I believe.
    I used grade 5's that were then drilled out for grease fittings.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The bolts are 9/16-18 fine thread in the rear springs in all three locations. 4 1/2" long sounds about right.
    Up front the stock bolts are 9/16-18 in the front of the springs and 7/16-20 in the shackles from the factory, similar in length. The exception to this is 88-91 trucks which use 1/2" bolts in the rear of the front springs.
    My factory bolts were grade 8s, not sure on others.
    9/16" bolts are not a standard size so they're kind of a pain in the ass to find. I paid $3 each for mine when I got them. /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif
