Bolt Size On Top Mount For Front springs
Discussion in 'The Garage' started by Cmoe, Mar 6, 2004.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    To night I busted the bolt on the top rear part of my front strings. The one that goes thru the frame. Does anyone know what size that bolt is? I also bent the stock brackets at the same time, does anyone have some that I can snag from them?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you mean the upper shackle bolt? that is 7/16 x 4" i think
    what bracket did you bend?
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Shackle brackets? 73-87 are all the same
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you mean these. how the hell did you bend these? /forums/images/graemlins/dunno.gif
    anyway if so i got some
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    No I mean the shackle it self... The two pieces that attaches the spring to the frame
    On the far right of the pic, is a set of aftermarket shackles. I just need stock to get it back on the road. [​IMG]
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have those also. i have a set of ORD shackles and bolts (non greasable) i dont have the bushings though. they are a different size because ORD uses 1/2" bolts instead of 7/16". $35 and their yours
    i have some stock ones but they are bent a little
