Bolt sizes from the factory
Discussion in 'The Garage' started by cybrfire, Jan 18, 2004.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Tried a search but found millions of results
    Does anybody know the bolt sizes for
    Rear springs:
    Frame to shackle
    shackle to spring
    spring to bucket (front of rear spring)
    Front springs:
    frame to shackle
    shackle to spring
    spring eye to bucket (front of front spring)
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    needin diameter of the bolts right ? i can look on my 83 and try to find out the sizes if you need ?
    whatever size bolts fit through the holes the best would be what size they are, what you trying to do exactly ?
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    diameter and length. I have a lift to install. Have new springs used shackles that are powder coated and would like to put the shackles on the springs and just cut the old bolts rather than try to undo them. They are so rusted their isn't much left to measure. I don't think I could budge them anyways. This way I can have the springs on the axles with shackles ready to go in.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All lengths are a guess, I really can't remember
    Rear springs:
    Frame to shackle 9/16-18
    shackle to spring 9/16-18
    spring to bucket (front of rear spring) 9/16-18
    Front springs:
    frame to shackle 7/16" diameter, unless 88 or newer or ORD upgrade, then 1/2"
    shackle to spring stock is 7/16" for rigs earlier than 88 or so, then 1/2" after that. The ORD upgrade is to a 1/2" bolt
    spring eye to bucket (front of front spring) 9/16-18
    I think they're all about 4.5" long. The front part of the front springs might be 5", as might be some of the rears. Hopefully someone else here can tell you for sure. It's been almost two years for me so I've forgotten.
