Bolt Specs for Dust Cover
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bluehen, Nov 30, 2004.
  1. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Howdy! Pretty new to the site. Haven't even seen it all yet, and I am amazed at the wealth of information here. I did a search on the following request and came up with nothing, so I hope this hasn't been asked before.
    What are the bolt specs for the dust cover on an '87 K5. 350cid and TH700-R4?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    does it have to 6 big bolts or the 4 little bolts?
    im not sure of the exact size but i know that both are metric. i actually need to know the size for the 4 little bolts.
  3. bluehen
    Nov 11, 2004
    215
    DE
    I need to go check, but if I remember right there are about 6, yes. Two of them are used for braces that come from up around the oil sump whic are probably the larger ones. The four others may use a nut on the back side of the cover. /forums/images/graemlins/confused.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Straight from my GM service manual:
    Converter housing cover...............25 ft-lbs
    Transmission support braces...........70 ft-lbs
  5. bluehen
    Nov 11, 2004
    215
    DE
    Sorry Heavy... Do you also have the bolt sizes? That's what I was getting at. I should have been more clear. I have a Haynes Manual, but there's no bolt sizes in there.
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I thought about this question last night as I lay under a parts truck staring at those dust cover bolts. If I can remember I'll check them but on my 87 they look to be a 14mm wrench size. /forums/images/graemlins/dunno.gif
  7. bluehen
    Nov 11, 2004
    215
    DE
    Thanks Man. I sure do appreciate it!
  8. heavy4x4
    Aug 28, 2002
    3,270
    Sorry James, I don't have the sizes...hopefully someone else can chime in.
