bolt up, or modify?....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kelboski, Sep 2, 2000.
  1. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    a guy has a 10 bolt front, and a 12 bolt rear from a 77 that he is parting out. they both have 4:11 gears....my question is....will they both bolt right up to my 84, or do the spring perches, and the shock mounts have to be modified to make them fit?......i want them to replace my 2 10 bolts, mainly for the gears...thanks in advance...
    Kelboski
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    They should fit cause axles on every 73-87 non dually truck (73-91 blazer and suburban) are supposed to be interchangable. Make sure you very that the gears are what he claims them to be. Take the diff cover off and count the gears or jack up the truck and turn the tires by hand once, and count how many time the driveshaft turns and divide the 2 numbers. This doesn't give you pin point accuracy but it is pretty close.
    [​IMG]K5[​IMG]
  3. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i like your little jeep recycler, chevy4x4.
    Knife.
    knife.coloradok5.com
  4. chevy4x4
    Apr 27, 2000
    1,454
    Thanks, I made it in an anamation program.
    [​IMG]K5[​IMG]
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    There should also be a stamping on the ring with a ratio which should be something like 41:10..
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
