Bolting a bender stand to the floor
Discussion in 'The Tool Shed' started by 8_YOUR_H2, Jul 7, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    What would be the best, most practical way to bolt a tube bender stand to the floor? I have a few threaded slugs that you pound into the drilled holes but they seem somewhat janky and I don't know if they would handle the torque.
  2. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I used some sleeves, and have some (big) lag screws to fasten the bender down. So far its real solid, even cranking on 2"x.120 DOM. Reason I used the sleeves is so when I am not using it and unbolt it there is nothing to trip over or poke a tire.
    Clay
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    get some 1/2" drop in concrete anchors, dont forget to get the tool too!
  4. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The stud thingies I used are grade 8 and have a little nub on the top you beat down with a hammer to expand the bottom inside the hole in the concrete. They seem to be working just fine so far.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I've been told by a concrete guy that the epoxy made for bonding studs in is the better plan. Doesn't stress the concrete like the expending fasteners do, so the slab is less likely to break up around the holes.
  6. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    agree...
    concrete epoxy is 4500 psi in strength.. equal to or surpasses the concrete... and they use it for many building anchors on big buildings
  7. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    X2, That is how I do it for my stuff, I had a vise on a stand just anchored with regular concrete anchors and over time they started to get a lot of play and started to pull out. Now ever thing that is bolted into the concrete is done the epoxy way.
  8. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    How does the epoxy stuff work? Can you still remove the item you are securing or is it permanent?
    They sell it at any hardware store?
    I have a vise stand I need to bolt down to the concrete.
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    it is VERY perminate. You would have to get the right stuff also. Hilti is the best. You can get this at a contractor supply house, don't think H.D or lowes handles Hilti but they may carry other brands. Drill the hole and you must blow out or vacuume out the concrete powder before you pump the epoxy in.
  10. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Also, make sure to pump in the epoxy first, then insert your all thread rod, and make like you are useing a plunger in a toilet to get it into the all the threads and pores in the concrete. this will also help mix in any left over dust you didn't get sucked out, preventing a bad bond to the concrete. start with what you figure will be too little, as you can always pull your rod out and spooge in some more goo. just work fast as sometime it will set up real fast.
    Also, try to be clean, as stated before it is permanent on everything like the tools you use, your garage floor, and of course you! Let it fully cure and then you can use it like a stud, i.e. add equipment stand and tighten nut. if you change your mind remove the nut and slide the equipment off and put a different piece of Equipment on it, retighten nut. so your mounting of equipment is not permanent, just the stud. To remove it you will need a Sawzall/grinder/torch, It will Never pull out. If you go to your local nut and bolt shop (copperstate here in AZ) and ask for "all thread" they will hook you up, they also carry all the epoxy and guns and load calculation sheets too. If it is in a wet area you can also get 304 stainless and 316 $tainle$$ $teel.
    We sold alot of this stuff along with wedge anchors too when i worked at a pipe support fabrication shop.
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    what exactly is the name of the epoxy, just ask for conrete epoxy?
  12. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Different stores have different brands, tell them you need two part or AB epoxy for concrete anchor bolts and they will know exactly what you need
  13. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
  14. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Exactly. Hilti. Glass vial, drop it in the hole, insert stud/ all-thread. Done. When it cures, the studs will break, or the concrete will pull out of the ground, not around the hole. Me and a few co-workers tried to pull the 1/2" stud out of the concrete as a test. No way, wound up cutting it off with a wheel.
  15. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Where have I heard that befoe?
    :haha:
  16. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Why is it everything I do is a total disaster.
    So I buy the special concrete bolts and drill bit. WTF ever...the bit got dull after about 1/2 a hole. Then the bolts just spun in the hole and never did get a good bite.
    So I moved onto the studs. Turns out the bolts hogged out the holes just enough so that the studs wouldn't get a good grip.
    Buying epoxy tonight.
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    Just saw this thread now or I would've warned you about the bolts. I got mine to work good once or twice. I went to my local industrial hardware store. Told them I wanted concrete fastners that I could remove and install numerou times and have a flat floor when they were removed. They talked me into the concrete lag bolts. I got them to tighten maybe two times.. After that some wouldn't tighten, some bent trying to tighten them, etc.. Waste of $$... I need to go back and get the expoxy'd in sleeve types....
    BTW, are the sleeves that come with the epoxy just a smoooth piece of threaded pipe/tube?
  18. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    What size plate is good for stand for say a vise? 12"x12"x 3/8" maybe? The reason I say 12"x12" is the metal yard here has precut pieces of plate that size in everything from 1/8" up 1" for cheap.
    Also when you use the epoxy stuff, you say to use all thread or studs...are there different grades...or will anything they sell at the hardware store work. Is there a common size stud to use for anchoring this kind of stuff?
  19. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I'd anchor with 1/2" size studs, minimum. I'd also try to find some grade 8 all thread, or cut the heads off of some long 1/2" bolts and epoxy those in. Make sure all the dust is out of the hole for maximum epoxy stickage. You will also want an impact drill to drill the holes, a carbide tipped masonry bit in a regular drill motor ain't gonna cut it.
  20. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Well you'd better get to it,I've been patienbtly waiting for pics of the finished project for 2 weeks now. You're almost as slow as I am...:D
