bolting on a 6.5TD turbo setup onto a 6.2 with mechanical injection
Discussion in '1982-Present GM Diesel' started by Pookster, Mar 8, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I know this has been mentioned before, just without much detail-
    Can I bolt on a 6.5TD setup onto a 6.2NA block without any internal modifications? Would the compression ratio be too high on the 6.2 block?
    are these all the parts I need:
    turbo, exhaust manifolds and intake manifolds, turbo charger
    Would the TD van setup work in a pickup?
    any other questions/comments Im forgetting?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I know this has been mentioned before, just without much detail- Can I bolt on a 6.5TD setup onto a 6.2NA block without any internal modifications?
    Yes, except there is mechanical interference from the AC box if you have one.
    Not necessarily, but if you have developing problems with your heads and/or head gaskets it could be the proverbial straw... Also if your CDR system is not working properly you will have a greater chance of blowing out your crankcase seals.
    are these all the parts I need:turbo, exhaust manifolds and intake manifolds, turbo charger
    Those are the major parts - in addition you would also want the intake tubing from turbo to air box, air box, crossover exhaust pipe, turbo oil lines and fittings, I can't remember if you need to go with the 6.5 injector lines and injectors due to interference or not.
    I believe that the rear mounted turbo interferes at the firewall.
    There are also some issues with the radiator hoses and crossover pipe (maybe I'm thinking Banks). It's especially critical on the 6.2 to get an exhaust pyrometer if you turbo it due the somewhat lower temperature limits on the 6.2 pistons as compared to the 6.5. Also there is the issue of adding more fuel (turning up the pump) and perhaps adjusting you fuel pump timing. Also you exhaust will need changing from the turbo out.
    I would make sure you do some basic diagnostic checks on your engine before investing in the turbo setup. I.E compression checks, CDR system checkout, etc.
  3. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    make sure the waste gate (if using the GM turbo assy) is working properly. If full boost is on too long, you will exceed EGT and crack pistons. Like Mark said, pyro is required to monitor EGT.
    The van turbo uses a 2-piece split intake manifold. This gets the inj pump out from hiding under the standard intake manifold.
    But the turbo itself is positioned on top of the bell housing. I would imagine you (might) could use the van manifolds, but all the turbo piping and mounting would have to be custom made.
    A van A/C housing is flatter than a standard one and helps solve the #8 glow and turbo interference problem.
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    If you're thinking of putting this on your 92 pickup, then it should bolt on without any problems. You should have the same a/c box as the factory 6.5L turbo trucks, so that won't be an issue.
    Otherwise follow the advice given above.
    Casey
  5. Steve_87K5
    May 26, 2000
    521
    central NC
    Casey is right, the A/C box problem applies to the 80s trucks which came 6.2NA. In these models, a van A/C box provides clearance for turbo transplants.
  6. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    So I take it the van a/c box will help out with the clearance problems with the factory 6.5 turbo parts on a 80's style cab? I have the parts to do it with just looks like it would be super tight getting the exhaust out with the a/c on the truck.
  7. dieselburban
    dieselburban Registered Member
    Jan 5, 2003
    21
    OWATONNA,MN
    Now I want to put a 6.5TD on my 6.2 /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
