Bolting rear shackles together to get more articulation???? anyone
Discussion in 'The Garage' started by alaskanbowtie, May 3, 2004.
  1. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    as it says I read on here somewhere that someone had bolted 2 sets of rear shackles together to get more drop??? Who has experimented with this and does it work well/safely and pictures PLEASE!!!!! I want to try it but would like some "been there done that" advice first. /forums/images/graemlins/bow.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    they won't just bolt together. Have to make spacers and bushings and such. People do similar things. I'm not a total fan of the drop away shackle setup, springs dropping have more control and less just simple drop.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So you want to go from the shackle hanging down like this: 1 , to two shackles hanging down like this: > , or two shackles hanging down like this: < . Sounds kind of like a revolver that doesnt revolve. /forums/images/graemlins/k5.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    often called a scissor shackle.
    this is butch's setup, a local boy running a Ramcharger sitting on 39.5s. His rear springs pretty much don't flex, its all in the shackles. He scores about a 900 something despite the springs. He fabbed that whole setup himself.
  5. alaskanbowtie
    Feb 15, 2004
    112
    ALASKA
    THX for the pic's that's great now if I could get some advice on the road manners when they have the scissor type shackle set up installed? and any more pic's of this would be nice of course...... /forums/images/graemlins/rotfl.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ha, well Butch claims his is fine, never gives him a problem, no unloading or anything. Not sure if that has anything to do with his stiff springs though.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    here's my setup. Drop tube not a shackle. The side plates help it hit back on center and there is a bump stop to remove the harshness. They are also pinable for the highway. As far as road manners couldn't tell you haven't gotten that far. I need to get off this computer and get back to work.
  8. alaskanbowtie
    Feb 15, 2004
    112
    ALASKA
    OH YEAH.... I like this creative engineering, why do what everyone else does, I think you have a great idea!!! Where did you get the piece in the middle that drops? did you make it and if so what size material did you use.....if that's not to much info to ask for. THX looks great! /forums/images/graemlins/waytogo.gif
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    the peice in the middle I made out of 2" square 1/4 wall. cut it to the length I wanted and then hole sawed the holes in the ends and inserted ORD's Heavy duty greasable bushing kit. It came with the tubes required to slide in the hole saw holes. Those were then welded solid. I think I'm going to have to add something that will prevent them from going over center in relation to the shackle itself. won't be hard to add it to there.
