Bolts for ORD flip? what to get?
Discussion in 'The Garage' started by sled_dog, Nov 15, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What size bolts do I need to get? All I know is I drilled the frame holes out to 7/16" and I need grade 8. I bought my flips from Yield2me(thanks again), and just need bolts and I can get going.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i have never installed one, so i dont know how many, but if you have the brackets then see what size the holes are. then go get the bolts you need. rule of thumb is you want a minimum of 2 full threads on the back side of the nut showing. a lock washer, then in my world some loc-tight as well.
    im guessing that they would be about an inch long.
    i dont know if any of this will help ya or not...
    Grant
  3. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    After the rivets were removed, the frame holes were then enlarged a little to accept the new 7/16 bolts.
    [/ QUOTE ] Here is where I got the quote from Offroad Design 4" Shackle Flip
    Hope this helps you out. /forums/images/graemlins/thumb.gif
  4. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Hey Sled-dog, run down to Lowes/Home-Depot and check out there specialty bolt bins. Matter of fact, since neither place really keeps them stocked, you will prolly have to go to both. Get the 7/16 bolts, 2 flat washers, lock washer and nut per bolt. I cant remeber the length, but I will check. I would of sent them to you, but I lost most of them when our shop moved. Let me run out and see if I can find one to give you an exact lenght..................
    BRB
  5. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    Ok...I found 2 of them, and they are 1 1/2" from the bolt head to the end of the threads.
    Hope this helps!
    Rob
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I figured they got messed up or lost or something no big deal to me I can just run and buy some.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We use a 7/16 x 1 1/4" GR8 with a pinchlock nut. Longer would probably be just fine.
