bolts or studs?
Discussion in 'The Garage' started by ou8mud2, Mar 1, 2006.
  1. ou8mud2
    ou8mud2 Banned
    Nov 2, 2004
    18
    Stow, Oh
    any pros or cons about using grade 8 bolts or studs in a D60f? in the process of puttin my 60 in and i was told that studs are better.have both available just wanted some opinions.thanks
    steve
  2. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    Studs are stronger than bolts. Also fine thread is stronger than course.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You have Grade 8 coarse thread?
  4. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    In high use areas where the thread will be used over and over I like studs. If I had to take my front D60 in an out 5 times a day (:crazy: ) studs would keep the holes from getting worn. I believe that a center section on a 60 is cast steel and will show wear long before the grade 8 bolt loses it's shine!
    I have put studs in a front 60 but they where step/repair studs to fix the badly worn taped holes. The previous owner thought he could "pull it" into position with a impact wrench :doah: !
    Both coarse and fine bolts/studs can be had in grade 8.
    Jeff
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    *cough* search *cough*
  6. ou8mud2
    ou8mud2 Banned
    Nov 2, 2004
    18
    Stow, Oh
    just looking for sime opinions D A!
