Bolts Question?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by joryyroj, Mar 24, 2005.
  1. joryyroj
    joryyroj Registered Member
    Mar 13, 2003
    32
    Wylie Texas
    Working on my blazer, about to mount the leaf springs, shocks, drivelines, and crossmembers to the frame. Does anyone know the specs for any these bolts? I dont have any of the originals, was thinking of maybe going to tractor supply and just picking up bolts, nuts, washers etc that will fit in the holes? Anyone know of anything wrong with that? Thanks in advance!
    Jory
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    As long as you use grade 8 bolts of the appropriate length,that should be fine.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    For the front you'll need 5" long bolts 9/16 up front and 7/16 at the shackle. In the rear you'll need all 9/16 bolts 4.5" long. as said all grade 8.
  4. joryyroj
    Mar 13, 2003
    32
    Wylie Texas
    Sweet thanks! Should I put washers on both sides as well?
  5. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    I did and use what I call "pinch" nuts, they lock but don't have nylon in them.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I allways buy the largest diamiter bolt (G8) I can fit, bigger bolts are better mmmK hehhee
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it seems that shackle ey bolts have no threads on shaft where they sit inside the bushings
    so i would think it would be good to find bolts just like that and not threaded up the shank like most are at the stores,
    no ?
  8. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Bolts
    Probably too late, but 'spring and alignment shops have the proper bolts, too.
