bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Sep 13, 2000.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    Anyone have a fix for a stripped torx bolt that needs to be removed...its a little rusted...
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Can you grind it off with a grinder?
    Or use a cutting torch?
    Where is the bolt located? Is it a tight squeeze to get to?
    Boss
    http://www.boss.coloradok5.com
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Or try and allen wrench or large flat screw driver. hese usually work!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Soak the rusted part in Penatrating Fluid, can't hert, only help.
    If you can get on the round head with some pipe wenchs that may do it.
    Good luck
  5. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    After soaking it in something to break lose the rust. Take a chisel and hammer and hit the bolt on the side and make it turn. Keep doing this until the bolt is high enough the get some pliers on it. I had to do this many times on Heep fenders when i worked at a body shop. Hope this helps.
    http://k5junkie.coloradok5.com/
  6. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    I've been able to hammer a slighty larger Allen Socket (funny, I don't recall the official name) into the head of the stripped torx and free it.
    <font color=blue>~BigBurban</font color=blue>
    http://www.geocities.com/crash607
  7. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    My seat belt torx's in the rear wouldn't come out. I twisted the torx driver you put in the 3/8 ratchet off. Craftsmen. I would drill it out personally or torch it.
    Doug Krebs
