bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by waterboy, Oct 15, 2000.
  1. waterboy
    waterboy Registered Member
    Jun 8, 2000
    48
    what is the best way to get off really rusty and really tight bolts
  2. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Hot wrench! (torch [​IMG][​IMG]) Actually I assume you want them out in one piece right? Warm them up first, you can use one of those little propane torches if you're patient. Heat it up real good and then put a big breaker bar on it. If it is a nut and bolt try and warm up the nut, this will make it expand a little and help break it free.
    I'm sure you've already tried penetrating oil right? If you have be careful with the torch [​IMG] if you have'nt try that first.
    Rene
  3. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,951
    247
    Released from Pueblo, told I belong in Southpark
    I have heard that you can ice the bolt from either side for a while and then heat the nut. Liquid nitrogen or freon would work well for cold. Air chisel??
