BOM # not coming up
Discussion in 'The Garage' started by 5trucks, Feb 23, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    OK! Im trying to find out the specifics on my front d44 and i cant seem to get the numbers correct. The only numbers stamped on the axle tube are:
    60345411 and then a space 6347 BE
    I tried all the combinations i could think of for this damn thing but i cant find it. Please help.
    http://www2.dana.com/expertforms/demenu.aspx?prod=AXL
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    what do you need to know?
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
  4. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    I need to know what year this axle is so i know what size spindles it has. I dont have digital or even crappy calipers.
  5. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    does it have hubs that are held on by 6 small hex head screws or 6 large 3/8" bolts? that will decide if it it small or large hub which wil help tell the year.
    why the need for spindle size?
    you sure it's a d 44? is the diff cover round or does it have a flat side?
  6. sandawgk5
    Oct 28, 2003
    6,881
    44s had 2 different size spindles the large spindle diameter is identical to a 10 bolt and the small is well smaller. It determines the wheel bearings that need to be ordered.
    Ira
  7. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    wouldn't the spindle sizes be determined by the large or small hub?
  8. sandawgk5
    Oct 28, 2003
    6,881
    Nope the inner race of the bearing is a different size. It is the spindle diameter that is different not the length of the spindle or the hub diameter.
    Ira
  9. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    how about just taking the old bearings to the parts store and matching them up before you buy them?
    i had a '76 big hub d44 before my d60. i thought they just went by years.
  10. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    It's definitly a d44. Says 44-5CF on the bottom rt web. Mostly it's cause i just want to know. The bearings are fine and all that. I am going to 8 lug so i should probably change the bearings out.
  11. sandawgk5
    Oct 28, 2003
    6,881
    So when you go 8 lug just put the spindles from the donor on it and be done with it. If it is from a 10 bolt they are all "big".
    Ira
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  13. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Yeah someone told me that from pirate awhile ago but i put those numbers in and it said error. Also, the gears are dana spicer gears and they are 3.73. Not that they couldnt have been changed but not likely.
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
    In my experience the BOMs are bang on the money. Since the ratio doesn't match, who knows who built it with what parts. I would determine the spindle size with a physical measurement.
