Bonzai Garage Clean Out
Discussion in 'General Parts for Sale' started by jays68yak, Oct 26, 2005.
  1. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    BBC Exhaust manifolds. Off of a 88 454, with AIR tubes and the connecting tube that goes around the back of the block. AIR tubes are currently off so if you wanted you could just plug them and not use the AIR tubes. Asking $50 obo
    89 4wd power steering box and pump. Still connected together. $20
    Stock D60 caliper brackets, nothing wrong with them, I just bought new ones before I ended up with these. $50 obo comes with used dust sheilds.
    Stock 60 upper bearing caps/steering arm. $20
    d44/10b superlift U bolt kit. Used, prob 6 trips on it. $20
    2 gas tanks skids, one uncut, the other has the mounting tabs cut. FREE
    72 chevy trailing arms. Good shape, no rust or cracks that I can see. Bushings would need to be replaced. $70 obo
    72 chevy stock disc spindles. Were replaced with drop spindles, nothing wrong with them. $50 obo
    Mostly complete SBC v belt pulley setup. I need to check to see whats all here. But its whatever came off of the SBC that was in the blazer when I went to the serpentine setup. $35
    Old beat up pair of BBC long tube hedders. No idea on brand or what they orginally fit. Could use some welding at the head flange I believe. $20
    8" lift springs should fit a 73-91 solid front axled trucks. Believe they have new/newer bushing. They prob dont even have that many miles on them. Buddy bought them for his chevy and then took them off. $180 obo
    Prices do not include shipping.
  2. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    top, blew tranny in towrig/dd, need money
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    shipping on the 8" fronts, to 97330 bizz addy.
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    there was a guy in the 1st gen forum asking about disk brake parts :wink1:
  5. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I told one about the spindles, thanks for the heads up Ill check it out.
