Boosted 6.2 problem
Discussion in 'The Garage' started by M-1028, Apr 17, 2006.
  1. M-1028
    M-1028 1/2 ton status
    Feb 2, 2005
    217
    Sealy Tx
    Specs -87 6.2
    gm 8 turbo w/ heath diesel boost controller
    My problem is the crankcase is getting pressurized and causing some oil leaks, when you pull the oil fill plug if sounds like your opening a soda. I used the factory 6.2 pcv canister that runs from the oil fill to the intake. What is the easiest fix for this problem, use the pcv valve off of a 6.5 or some another boosted motor. I am clueless on how the 6.5 is set up so any help on this would help.
  2. M-1028
    Feb 2, 2005
    217
    Sealy Tx
    I think I found my problem, I ran the canister from the oil fill to the intake when it needs to go from the oil fill to the intake before the turbo. Like an idiot I was sending boost directly to the crankcase.
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    That's actually kinda funny...deserves one of these >> :doah:
    Glad you got it figured out.
    Rene
