Booster and master cylinder upgrade?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Boondocks, May 17, 2005.
  1. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    Has anyone ever swapped out the brake vacuum booster and master cylinder for a new smaller unit that does eat up so much space in the engine compartment?
    Since I installed the SureFit A/C conversion, it really looks odd having that huge setup on the driver's side a almost nothing on the passenger side.
    Besides the whole thing is still original as far as I know and will most like need replacing soon anyway.
    Also, if I go with larger tires, wouldn't it better to have more braking power?
  2. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Going to a 3/4 ton booster is a good/cheap upgrade that really works.
  3. Boondocks
    May 10, 2005
    129
    Massachusetts
    I believe I saw some discussion on that in on one of the forums.
    I'll track it down and get the details.
    Maybe I can balance out the appearance under the hood with the fire supression system from another discussion.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I believe this is what you're looking for:
    http://coloradok5.com/forums/showthread.php?t=85972
    if you scroll down its probably 20 or 30 posts below this thread in the 69-72 forum.
