BOP 455....
Discussion in 'The Garage' started by RustBuket, Jan 25, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    There is a local guy with a buick 455 and he says it'll bolt up to any chevy tranny. What other kind of modifications would my '81 Blazer require to shove a big block in it? Its fairly cheap but needs rebuilding. Anyone got experience with this swap?
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    BOP motors are just that... Buick, Olds and Pontiac. The tranny bolt pattern is specific to those three only. Chevy tranny's won't bolt up as far as I know. I have a Buick 455 I want to put in a 4x4, and I'm going to have to use the Buick TH400 tranny and a divorced T-case. I suppose there are other ways you could make that motor work in a 4x4.
  3. RustBuket
    Feb 21, 2003
    1,618
    So basically it would be a completele redesign of the drive line... Well that sucks because I was hoping it'd be easier than that... O well I'll keep my eyes peeled for a nice 454 or something. Or maybe I should just stick with the freshly rebuilt 305 that has a few hundred thousand more miles to live yet.... /forums/images/graemlins/rotfl.gif
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Well, a 454 would probably be better and easier.
    I've heard that the Buick 455's are a little different than the Olds and Pontiac motors. The Buick motors have the distributor in the front which mounts through the water pump, and I've heard this is a worse setup than other Olds/Pontiac 455's. But I'm no expert on these motors.
    What tranny and T-case are you running now and what do you want to run?
  5. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well no, you can buy an adapter for like 80 bucks from summit or jegs.
  6. RustBuket
    Feb 21, 2003
    1,618
    Alright guys thanks alot. I think I'll stick to chevy being as this motor had a knock when it was removed and two rods need replacing (who replaces two rods?) and the crank needs regrinding. etc! But a 454 would be very very very sweet!
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    An adapter for mating a BOP motor to a Chevy tranny can be used. They can be found for less than 80, not that difficult to find.
    It depends on how much of a challenge you like. BOP swaps aren't that difficult, but can be time consuming....
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It will bolt up to a Chevy tranny, only the th350c and 2004r with dual bellhousing patterns. Mostly found in gm g-body cars. So just get a 350 chevy, almost everyone has one in their backyard somewhere. /forums/images/graemlins/thumb.gif
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You might want to ask 84K5BD. He's a cool guy and has a sweet K5 with a 455 under the hood.
  10. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    WAIT! There IS a way to bolt a Buick 455 up to a sm465 tranny!!!
    There are two ways to do this:
    Pre 1981 chevy-gmc diesels. They used the Olds 5.7l diesel bolted to a sm465. Supposedly these will work. However these trucks are very rare. 've never seen one and only heard of them a few times.
    The second, and easiest way, would be to go over to a Jeep bellhousing maker. Jeep guys love using Buick V6's and sm465's. Bellhousing bolt patterns on Buick V6's and Big Block Buicks are exactly the same. The bellhousings run around $300 new.
    As for Olds and Pontiac 455's I can't help ya as they use different bolt patterns. But I hope this helped out some for the Buick!
  11. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    It is called BOP (c) for a reason, all the same tranny bolt pattern. Oddly enough, Chevy was the odd man out, and look who won in the end, because of favoritism /forums/images/graemlins/eek.gif
