BOP TH400 Questions...
Discussion in 'The Garage' started by mikey_d05, Jul 9, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Alright, I'm swapping a Cadillac motor into my project and it uses a BOP bellhousing pattern. I landed the matching TH400 when I bought the motor. It's gonna get rebuilt next Saturday and I'd like to put in a full manual valve body and a new torque convertor at the same time.
    When I look on Summit Racing, under application, it always says chevy next to bellhousing pattern. Is any of this stuff interchangable or am I up a creek without a paddle?
    The TC bolt circle is 11.5", so I know the convertors I've found will bolt to the flexplate...is it an issue with them clearing the bellhousing or what? Also, what's the deal with the valve bodies? There has to be something that works in these BOP TH400's or nobody would ever run them.
    Thanks in advance for any help guys.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    AFAIK everything is the same except the B/H pattern.
  3. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
  4. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    All the internals are the same on BOP & Chevy, like was said in above post just the B/H pattern is different. I went through all this years back when i built my GTO.
