borrowed truck cranks but wont start NEED HELP!!
Discussion in 'The Garage' started by speed_deed, Jun 8, 2004.
  1. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I'm borrowing my buddies 86 suburban for a few days. I parked it last night at about 7 I went out to start it this morning at 9 and it wont fire up. It cranks but wont fire. Its not flooded. I really really need help!
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    start with the basics, take a fuel line off, crank it and see if fuel is coming out. if so then pull a spark plag wire and hold onto the end if ya got balls or stick it close to something metal to see if it sparks. There werent any problems with it when you drove it last though? Sounds like an ignition problem though. Is the HEI?
  3. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    I've already checked and the fuel pump is working. This is HEI.
  4. monsterjim
    Feb 5, 2004
    151
    north Texas
    check for spark then, I bet the coil on top of the distributor is out. Does it just turn over and over with out even a hint of wanting to go vroom?
  5. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    Thats exactly what it does.
