Boss or anyone that has installed a 1" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Dec 29, 2001.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Boss or anyone that has installed a 1\" lift
    Should the 1" puck be like this or should it be under the washer thing it is sitting on?
    <a target="_blank" href=http://community.webshots.com/photo/23318486/23318676rnYaiZvCNx>http://community.webshots.com/photo/23318486/23318676rnYaiZvCNx</a>
    Steve
    Director of Global Expansion
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Re: Boss or anyone that has installed a 1\" lift
    This installation is correct. It couldnt fit under the washer thing because of the oblong shaft that goes down through the bushings.
    Brent
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    That's the way mine are too...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. Re: Boss or anyone that has installed a 1\" lift
    who's beautifull rig is this!
    <a target="_blank" href=http://community.webshots.com/photo/23318486/23320334IFpSpzQMmX>http://community.webshots.com/photo/23318486/23320334IFpSpzQMmX</a>
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Those pics are of Boss's truck.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    Thank's guys, it looks like I have three different length's of bolts for the 1" lift anyone know which locations the different length's go?
    Steve
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I used the bolts coming out to figure which bolts were which. The new bolts are all exactly 1" longer...[​IMG]
    Of the ten bolts supplied there should be two of one size, then 4 of the second size and 4 of the last size. The size that there is only two of is for the rad support and get the nuts. Of the remaining bolts the 4 shorter bolts are for under the cab and floor by your feet, the longer 4 should be for the bed area.
    The ones going through the bed are tack welded to the floor from the factory so you'll have to grind some...I ground those ones flat and pounded them down through the old mounts.[​IMG] The ones under the cab area have the most potential to ruin your day, I had one snap off flush. I had to drill it out and re-tap the hole. Hopefully you don't have my type of luck...
    Rene
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    Thank's, I aslo planned on just looking at the bolts that came out but in a cramped garage with cords knocking the stuff laying on the floor around and getting mixed up, you know how it goes. I have just one bolt in the rear to get out and the two front ones the others are out, the four middle ones came out pretty easy.
    Steve
  9. CK5
    May 19, 1999
    21,623
    701
    CO
    I will also point out that it is 20 degrees in my garage and I need the K5 to get to work tomorrow BUT football starts in about an hour and it is toasty inside - DAMN
    Steve
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    LOL! Sounds ruff over there Steve! ;) Good luck with the body lift. I have the ORD 1" and its great. Only thing I didnt do was disconnect the tranny linkage and steering shaft before I did the install. In the process of lifting to get the pucks in, I tweaked a seal or something in my steering box, its been a leaker ever since. Other than that, the install went without a hitch. I like getting the extra inch of clearance and not having to modify 20 things to get it to work. Just adjust the tranny linkage and GO! =)
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Steve...make sure to check the fan to shroud clearance, I had to trim the lower half of mine after the body lift was in. I was about to start my truck up before I noticed the fan tight against the shroud when I did the 1" body lift.
    Rene
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I guess you forgot to ask Santa for a heater for the garage huh? [​IMG]
    Rene
  13. CK5
    May 19, 1999
    21,623
    701
    CO
    Now for the fun part, I can't get the fawken front bolts out, they are fused to the metal collar or something, any ideas? I trieded pulling the front grill to gain better access but can't get to the center grill screw without pulling the 215 pound front bumper and winch (I refuse to do that).
    Steve
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I had to pull my grill...once the grill is off acess to those bolts is relatively easy. FWIW I broke my grill taking it out[​IMG] but my prob was with my hi-lift jack mounts being in the way. Bad engineering on my part.
    I just had a better look under the front of my truck and it looks like you could remove the lower facia that the grill is attached to on the bottom...two bolts on each end at the fender, and one in the center. The one in the center may be accessible or not if you can't get the center grill scew out...
    The only other option is removing the bumper/winch...or calling the Spickler Cab co. in the morning for a ride to work.[​IMG]
    Rene
  15. CK5
    May 19, 1999
    21,623
    701
    CO
    Removing the bumper is not an option, I can get a socket on the bolt head through the grill, but the bolt is fused to the body mount prolly a metal collar in the center.
    Steve
  16. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Have you got the nut off on the bottom? If so can you drive the bolt upwards and hopefully break it loose? If you were successful with that can you fish the new bolt through the grill?
    I understand the hesitance to remove the beast from the front of the truck...I'm just not sure there is a workable alternative.
    Rene
  17. CK5
    May 19, 1999
    21,623
    701
    CO
    OK, I got the grill off, I was able to remove the center support and the bottom body piece along with the grill still attached to it. Yeah, I have the nut off the front even raised the body and stuck a piece of metal under the bolt then lowered the body back down hopeing the weight would force it through, no luck.
    Steve
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    OK...I think probably the bolt is rusted to the steel sleeve and the sleeve is frozen in the rubber mount. Try drilling the rubber mount in various places from the sides. You could also jack the body and cut the bolt with a sawzall...take it out in pieces. A grinder with a cut-off disc would work too.
    Rene
  19. CK5
    May 19, 1999
    21,623
    701
    CO
    Woohoo, I got it, put the torch to it again raised the body up and then put my ORD steering arm under the bolt side ways(don't ask) then lowered the body and it poped free.
    Steve
  20. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Cool, you got medievel on it![​IMG]
    Did you get both of them off? Maybe you won't be using the Spickler taxi service tomorrow...[​IMG] gonna be a late night though. Have you pulled the shroud yet? It's a real bitch after it's lifted if you haven't done any pre-trimming.
    Rene
