bottom end eng repair with eng in rig?*** Follow up question!
Discussion in 'The Garage' started by xtrmjoe, Aug 3, 2006.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    Have a rod bearing that went. While taking it apart the crank bolt on the main pully broke off. So I am looking to do new crank and bearings, from summit. 350 4 bolt main in 86 K5 with 700r4
    Can this be done with the eng in the rig?
    I did search did not find much
    Thanks in advance
    *** I knew it was a bad idea as soon as I typed it but thought I would check.
    Is there any trick I need to use to get a engine out of a blazer with 7" of lift and 37" tires. All the cherry pickers I have seen dont seem to be tall enough to get the engene high enough to get it out. I am sure there are bigger ones I could buy but if renting one how do I make sure it will work?
    The other reason I was asking is because I have the ord eng crossmember to put in so I was gonna cut out the old one to make more clearence in there.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    It would be way too hard since the tranny would need to be moved backwards. Also you ever try to hold a crank over your head and also hold 8 con rods all at once? Pull the engine and do it correctly. Also if you lost a rod bearing the whole engine should get taken apart and the block boiled clean so as to remove any metal particles that got trapped in the oil galley's.
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    yep...
    Pulling the engine is the only way--its possible to do an "in chassis" overhaul,but I'd reserve that for cruel and unusual punishment only!--you save NO time,and your back will never be the same again,ever...
    I did a set of rod and main bearings,but used a cotter pin bent a certain way to "roll" the shells in the mains..it sucked,it was 8 hrs of oil dripping in my eyes..and the motor only ran a few months before it REALLY seized tight!..(something I fully expected,since the crank was scored pretty good)..I'd just get another engine and drop it in,unless you've got thousands invested in this one or something..:crazy:
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As everone said. Dont do it in the truck. It aint worth the time, trouble and pain. Far easier to pull the engine.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Rent a cherry picker or borrow one. Just like the other replies, if you just throw a crank and rods in it, you'd be asking for trouble. I'd start looking for a replacement engine.
  6. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    absolutely right. i almost tried that, to save a buck, but it would have been way too much hassle and left hidden damage that would bite me in the butt later.
  7. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah I think I saw that movie. Too much blood and guts, foul language. X rated, bad plot. Don't go there.:haha:
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    don't know where you're located, but i've got a cherry picker here in portland which you could use if you're nearby.
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I swapped a crank without removing the engine a long time ago.
    It was a 4.3 liter in an Astro van.
    I won't be doing that again.
  10. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    All I have to say is use a lil' common sense, you can pull the motor in under 2 hours esy. I can do mine in less than an hour but I have swapped motors multiple times. DO THE JOB RIGHT! Work SMART not Hard! One place you CAN NOT cut corners is in Engine rebuilding! As said Block must be cleaned, Crank Ground, Cylinders bored/Honed, New Pistons?, Bearings,ECT.....................GOOD luck ps Buy a crate motor and swap it in is the easiest fix, Half a day and done.
  11. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    maybe stateing the obvious but.......
    pull the 37's.....get a set of junkyard stock steel rims with no rubber....bolt crap rims on....wedge & block till secure. much lower working height = good
  12. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    thanks for the info. I have done everything to this rig mysealf so far but the engine so its a new one for me. Them blocks are some heavy son of a guns and i did not want to get halfway into anything with out being sure I could finish.
    Where I am working on this truck is a hour plus to anywhere to rent/buy get parts and pickers, plus the cost of gas these days. so I had to explore all options.
    I may just go for a crate motor.
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    It cost less $ and time to do it this way.
    Harbor Freight @ $130.:D
  14. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Buy a GM crate motor with their awesome parts and labor warranty, swap it in, and call it good.
  15. 81K5GUY
    81K5GUY 1/2 ton status
    Jan 30, 2006
    943
    Rockingham ,N.C.
    also if you take the radiator support and grille out you wont have to jack the picker up as far
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    On mine, I set it down on the axle to get the engine up-n-over.
    GM crate motor by the way.
