bottom leaf on front pack has wavy end
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 17, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    why are ends of bottom leaf of my front packs wavy ? special leaf or ?
    thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    wavey? gotta pic?
  3. dyeager535
    26,982
    191
    Sounds like what happens from an accident. See "wavy" ended front leafs all the time in the wrecking yards, when the front axle is stuffed backwards. (or the nose/frame gets bent, altering the spring mounting locations)
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no, its not accident, both ends are shaped the same, its some kind of special leaf of some kind, i dont know what yet.
    if youre looking from side of truck at either end of bottom front leaf the ends are wavy up and down- vertically, almost S-curve, sorta, a flat S-curve., the same amount and identical on both ends of it
    thanks
  5. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Could be an old add-a-leaf??/forums/images/icons/confused.gif
    Rene
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Does it have aftermarket overload springs on it? I know most are curved to accomodate a clamp. Some pics would help.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i wish i had a digicam...
    how many leaves would be factory on a 79 K10 ??
    Ill find the SPID label and see if it lists any F codes hmmm..
    it doenst look incorrect or anything, but if i decide to add leave to the front packs then id have to either add them above this leaf or simply just do away with it.
    thanks
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no idea, i dont knw what add a leaf are supposed to look like, hmm..
  9. dyeager535
    26,982
    191
    The K5's couldn't get anything but 2 or 3 leaf fronts AFAIK, (only one front spring option for the K5's) I'd assume K10's would be the same.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah its got two normal every day looking leaves and then this oddball looking leaf underneath them two- same deal on both sides of truck
    thanks
  11. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Does it look anything like this?
    only on the bottom?
