bought 79 c10, fulltime 4x4
Discussion in 'The Garage' started by OffRoadOhio, Oct 26, 2003.
  1. OffRoadOhio
    OffRoadOhio Registered Member
    Mar 5, 2003
    87
    Lancaster Ohio
    bought a 78 chevy, 350,auto, with np203 fulltime case, missing a bed, and has soem rust.... for $200. fixing it up for a tow rig.. anyoen knwo how full4x4 does towing?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Works just fine in my burb, nothing special to know, just tow like any other rig /forums/images/graemlins/thumb.gif
  3. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    ok thanks
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    A 4wd is a K10, 2wd is a C10. /forums/images/graemlins/thumb.gif
  5. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    and is it a 79 or a 78? /forums/images/graemlins/confused.gif
  6. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    its a 79 silverado. emblem says 10, so i'm guessing that means k10.. the c was my bad... i was thinking gmc was k and chevy was c.
  7. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Cool, for $200 sounds like a deal. You gonna put a flat bed on it or another stock bed?
  8. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    My cousin had a bed that needs soem repair, he siad I could have, and there is also a friend of mien with a almsot perfect bed for 150, so i'll probably go to a stock bed with a cap, so tha tI will be able to keep my stuff locke dup, while i'm on the traila dn the truck and trailer are sittin
  9. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    Here are the pics
    Can any of you guys help me out with what axles I have?
    FRONT (sorry its kinda dark)
    REAR
  10. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Axles look like a front 10 bolt, and the rear kinda looks like a 14 SF???? Kind of hard to tell on the rear axle.
    How do they tow? That depends on how much you want to tow, gears, and the condition of your springs.
    Looks like a nice start you have there....Maybe that rear is a 12 bolt. Send better pics tomorrow....
  11. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Good buy for 2 bills /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  12. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    Do I just count the bolt son the diff cover?... the rear cover ahs 12
  13. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Where the wheel bolts on to the hub,does the center stick through the rim and is there a circle of bolts?
  14. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    its a 1/2 ton, no bolts, bolts would make it a full floater right?
  15. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep,Could be a semi Floater,need a better photo to tell.Six or eight lug?
  16. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    6. I'm figuring 10 fronty and 12 rear, like most have said. If that is the case how strong are these, will they hold 35, if I dotn do any hardcore wheeling? I dont plan to take it offroad much anyhow becuase its going to be a tow rig. I dotn want to lift it any higher than the axles will hold, becuas eId otn want to get into swapping axles in a 200 dollar tow rig
  17. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    10 Bolts will be fine for a tow rig........
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nice buy !
    dont looklike it has hardly any rust from the pic, cant see any holes ?
    front can be 44 or 10 bolt, both are 10 bolt covers but different shape, either could be under the front of a 77-79, and plus some light 1/2 ton trucks(56 inch 4-leaf packs) got 10 bolt rear 77-82
    203 is not weak, it is cast iron case, you will be fine unless has massive internal wear
  19. OffRoadOhio
    Mar 5, 2003
    87
    Lancaster Ohio
    found out today it ahs limited slip in the rear
  20. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Sweet, I wish I had a limited slip. Then, maybe I wouldn't have been stuck last night~! /forums/images/graemlins/thumb.gif
