Bought a '74 C20 Crew Cab today - Project ShortBox Crew Begins
Discussion in 'The Garage' started by MTMike, Apr 20, 2006.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    So I came across a C20 Frame & cab for $100 today, offered him $75, he took it, and I'll pick it up on Saturday.
    1 of 2 things will happen:
    1) Cab swap onto my shortbox frame, bob the bed (a LOT) custom fab tire clearance in the back of the cab corners
    2) Frame swap my powertrain to the 20 frame, lengthen my wheelbase slightly, have a longer bobbed bed and have clearance for the rear tires w/out cab mods
    If I think I have any chance of finishing by early July, I will start after Memorial Day, otherwise, I will wait until after Divide Ride in Mid July.
    I will take as many pictures as possible during the process. Wish me luck! My buddy Joe's already offered to help and I need all the help I can get
    Mike
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    :D 1 ton, with a shortened bed, frame and 1/2 ton axles:D
  3. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    :doah::haha::doah::eek1:
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I think it would be simpler to swap cab onto your chassis but the again the 1-ton frame is stronger unless the 2wd older ones are different. Still a major process no matter what way you look at it. Wouldn't have to screw with shafts if cab swap though
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    That's what I was thinking too, and thats probably the direction I'm going to go with it though.... Joe's convinced it'd be about equal but I'm not buying it :)
  6. MNorby
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I could set ya up with some metal 55 gal drums. Take a section of that and fab into the back of the cab and make a half way fander in the cab corner to clear the tires.... maybe and idea :confused:
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    That might work. I'll have to get some measurements first & foremost. I may not need to do anything, or just trim overhang.
  8. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    The crewcab, while nominally a 3/4, has the 1-ton frame, i.e. thicker, narrow spring spacing, etc. If you're worried about it, that's the frame to use, PITA though it may be to swap.
    -- A
