Bought a new aluminum water pump.
Discussion in 'The Garage' started by DPI, Aug 29, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The quality sounds pretty good and the price was awesome for an aluminum pump for my setup. The company that manufactures them is called CAT. I never heard of them, but after looking around on their site and talking to them, I ordered one from Gambardella out of Williamstown, NJ. It was $71.99 for a polished aluminum pump. The only other aluminum pump I could find for my application was @ summit for $151.95 for an Edelbrock that is not polished, the polished pump was $249.95. Polishing really was not important, but hey I'll take it.
    Has anyone used one of these pumps? If not I'll let you know how it turns out
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What are the benefits of a pump like that?
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    1. Higher volume will flow more fluid and should help to run cooler.
    2. Higher pressure will raise the boiling point.
    3. Aluminum dissipates heat faster than iron.
    4. Bigger shaft and bearing, should last longer? May be pushing it here.
    5. Aluminum is lighter than iron ( not a big deal since I have a 125 lbs winch and 120 lbs of tubing up front anyway).
    6. Aluminum is COOL! /forums/images/icons/cool.gif (now I am really reaching for some justification for the pump) /forums/images/icons/grin.gif
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Aluminum does not rust
  5. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    One more plus is that when the pump is trashed, Aluminim has a higher scrap rate than iron /forums/images/icons/grin.gif .
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah, Or you can just rebuild it. /forums/images/icons/wink.gif
  7. Calclips
    Apr 4, 2001
    1,005
    Yeah... I suppose you could do that. Hmmmmmmm.... thats alot better of an idea than turning it in for scrap, especially since you'd still probably only get like 50 cents...
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sounds like for $72 its worth it.
  9. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Dang, I just bought the stock replacement at NAPA for $32! Wish I'd known about this brand before. I guess I'll book mark it for next time. Thanks for the info!
