bouncing speedo!
Discussion in 'The Garage' started by southernspeed, Feb 8, 2004.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Is there any fix for the bouncing speedo needle on the older trucks? /forums/images/graemlins/confused.gif
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    speedo gear might be missing a tooth, or go get some graphite lube at the parts store and squirt it down the cable to lube up the rotating cable.
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    You could try lubing the cable, but from what I've read, it's possible that the speedo itself is trashed. I greased mine up a few years ago, and now it's worse than ever. Apparently, if you don't use speedo lube, the greasy/oily stuff can get up into the speedo itself and wreck it.
    I have a new speedo cable I'm going to try. After that, it's new speedo (or rebuild, or whatever).
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Take the speedo out to a shop and have it repaired or replace it.
    Bill
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I have had success with pulling the cable out and lubing it with Auto Trans Fluid. You can also add a few drops of ATF to the gears, etc in the speedo to lube things up.
