? bout 14blt swap
Discussion in 'The Garage' started by oatsk5, Sep 18, 2005.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    so i got the 14 blt in and hooked up the drive line and noticed that the shaft is at a slight angle to the t-case is this normal mabe i just never noticed it
    before any help would be cool
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    it should be at the exact angle that your old 10 bolt was at.
    the only way to adjust it is with taperd blocks or shims bolted on to the spring pack. if you didnt change any of the suspension it should be where it was before.
    its not bad that its angled up toward the tcase as long as it is just a little. it does this to reduce bind in the driveline
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Well, it might be at the same angle. if the center of the spring perch to the nose of the yoke on the diff is longer on the 14 bolt then the 10 then the angle will be slightly steeper.
  4. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Are you talking left to right or up and down angle. If left to right don't worry about it, it won't hurt. If up and down it will only matter if you have driveline vibrations or not. If it vibrates you will chew up Ujoints and possably, eventually pinion bearings.
  5. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    thanks for the replies 6.2puller read my mind i meant left to right sorry for not being more specific this is the first time ive done the swap to 14blt thanx again for the help fellas
