Boxed frame. Yay or Nay?
Discussion in 'The Garage' started by Custom6.2, Jul 17, 2006.
  1. Custom6.2
    Custom6.2 Registered Member
    Jul 17, 2006
    5
    California
    Hey everyone, first of all, this is my first post as I am new here. I hope to have some good talk about off-roading with all of you as it is a passion of mine.
    Ok, I have a question about boxing frames. What are the benifits? I know that when I am out flexing on rocks and whatnot that the flexing frame makes up for mediocre suspension. To counter act this, I would believe that making the frame stronger and upgrading suspension would be key not only to better handling but calmer piece of mind. ANy help on this topic would be greatly appreciated.
    1984 Custom Deluxe
    6.2 deisel
    6-inch Skyjacker lift
    37-inch tires
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    If you are gonna box, I say, do it from front to rear.
    If you do bits and pieces the frame will crack at the edges of the box. ask me how i know.
    i did mine. you can see them in my pictures. i used the same thikcness as the frame--3/16
    time consuming, but worth it in every way.
  3. Custom6.2
    Jul 17, 2006
    5
    California
    Thanks for the insight.
    Where can I see your pictures?
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    if your gonna run a cage just securely tie the cage into the frame. its stronger and much easier.
  5. Custom6.2
    Jul 17, 2006
    5
    California
    Yeah, youve got a good point. I was planning on caging the engine bay all the way through to the bed. The more I think about it, the better it seems. Two birds with one stone.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cage is going to stiffen it up quite nicely, I wouldn't worry about boxing if you are doing that much cage work.
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm going to box and tie all the tube work into the frame. It's sound theory and apparently 85mudblazin's truggy is putting some pretty big stresses on his frame because it's not boxed and wants to bend where it's not supported by tubes.
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Another thing you might want to consider, if you are going to take your truck down to the bare frame, is cut off and remove all the factory rivets from the frame. Then replace them with Grade-8 bolts and locking nuts. The factory rivets get loose over time, especially if you take it off road a lot.
  9. Custom6.2
    Jul 17, 2006
    5
    California
    Ah, cool tips. Thanks for that.
  10. bgreen
    bgreen 1/2 ton status
    Jun 12, 2004
    167
    Alaska
    I would recommend doing both the cage and the boxed frame, neither alone will be enough to make a completely stiff and reliable chassis. I wouldnt get carried away with the plate though, something heavier than 1/16 but lighter than 1/8 would be my preference. 1/8 if there is nothing else available.
    I have a multi (more than 8) point exo with plenty of triangulation, boxed frame, and basically solid motor and tranny mounts, but I can still stick my hand between the cage and cab, or cab and tranny, and feel things moving around a bit. I'll be throwing a bit of in-cab triangulation and building some more drivetrain x-members next winter to help change that.
  11. Custom6.2
    Jul 17, 2006
    5
    California
    Well that sounds like the optimum route to take.
    What are you driving by the way?
  12. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
