boxed frame ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Dec 20, 2002.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Has anyone boxed their frame I plan to the question I have is did you weld the box so there is a lip of the frame still sticking out or did you weld the plate flush with the frame. I am considering this a manditory mod on my rig it is a 73 I plan on running a D60 and 14FF about 4" of lift and 38 to 39.5 tires with a mondo flexy suspension (rip out all the mounting points and start over)Also I am a beginer on Blazers so any helpful points would be good.
    Thanks Eric /forums/images/graemlins/truck.gif
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Go to www.socalbigdawgs.com and look up "the beater".
    His name is Chris. He has a 73 blazer with a boxed frame (after he went throug 2 other frames), D60's front and rear, and 38" TSL's.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If that is what you are doing, you might also consider another route.
    I had a friend that had a nice setup with 1 ton gear and 44" tires and in the end, after boxing it and still not geting it strong enough, he got a 1 ton frame, and a blazer frame and used them one inside the other.
    I like that better than boxing because you can still run things in the chanel and have access easy.
    /forums/images/graemlins/thumb.gif
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Dang.. I'll bet that was heavy! I'd like to see pics though, sounds like a cool project.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Boxing it is very time consuming. You would get better results from just making a new frame from tube steel.
    CHeck oout this guys set-up...just another guy I found on the net who like me had purchased a fiberglass body from US body source.although mines a K5...
    Kool Truck Project
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Sorry no pics. And the truck was parted when he purchased a new TJ and transfered all the running gear to it.
    It took a lot of work obviously because it won't all fit, the long section between the front spring hangers and the rear axle spring hangers is taller on the 1 ton, so that part was easy but in the front and the back it was more involved.
    As for the weight, he had a healthy built 454, with all the goodies, and deep gearing in the detroited rear 14b FF and frnt D60.
    He just went with a Jeep because he said the trails he likes are narrow and this thing didn't fit.
  7. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    are we talking about boxing just the steering area or the whole thing? Does the rest of the frame develop issues after hard wheeling as well?
    andy
  8. mrjay
    mrjay Registered Member
    Jul 16, 2002
    6
    Northeast Florida
    I haven't done it myself, but the guys at 4 Wheel and Offroad Mag have talked about it. One of the issues that they brought out was that you should box the whole frame. Just boxing one section of the frame shifts the stress back to the un-boxed section. Once you go the route of boxing the whole frame, it might be easier and not weight any more to go with the one ton frame.
    Jay
    86 K5 - 'nough said!
    I had a Ford once, then I grew up. /forums/images/graemlins/k5.gif
  9. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    I broke my 1-ton's frame at the steering box, so it was boxed, then it broke again right behind the box when it hit another car hard enough to wrinkle the frame an inch back.
    Has anyone had problems with their frame cracking from stress in other places than the steering box?
    andy
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't know about 1-ton's but 73-91 Blazer frames suck!
    I know meny people with cracks all over their frames.
    The most common areas are around the steering box (even with a brace) and around the rear shock mounts.
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can put me into that club! /forums/images/graemlins/frown.gif
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    When ever you strengthen a plce the next weakest place cracks.
    You have to reinforce the whole thing or don't do anything at all. /forums/images/graemlins/grin.gif
  13. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Another approach that I think is much easier is to plate the outside of the frame. My frame is plated from just behind the steering box all the way back to the rear bumper. I also used 3/8'' plate which is probably overkill, 1/4'' would suffice. I removed the body mount bracket and welded them back to the outside of the plate. I run a link and coilover suspension front and rear with an extreme amount of flex. When completely flexed I can open and close the doors and hood as if it were on level ground. I think boxing the frame is equally as strong, but would be a pain unless you have the frame completely bare. /forums/images/graemlins/thumb.gif
