boxing in frame
Discussion in 'The Garage' started by reptilianman, Apr 11, 2006.
  1. reptilianman
    reptilianman Registered Member
    Apr 9, 2006
    12
    clarkston , michigan
    I've bent the second frame under my 78 k 20 and was wondering if any body has boxed in there frame , or if its worth while , or tips on doing it if possible.
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    where did it bend?what did you do to bend it? boxing it isn't that hard just time consuming. you'll have to buy some 8" bar stock i think 6" is just short. you can clamp it to the frame and mark the contours of the frame or you can make cardboard templates. probably 3/16 or 1/4" plate.
  3. dyeager535
    26,979
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    If your bending them up that bad, you might be better off just running new 2x6 or 3x8 tube steel as new frame members. Do you have a cage? A full roll cage tiied to the frame realy tightens up the flexy stock frame.
    Just out of curiosity, where are you bending up your frame in Clarkston?
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Just keep in mind if you bos a frame you want to box the whole frame. If not where the box ends and the channel begins will see a lot of stress and crack.
  6. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    If i wanted to partially box in my frame in just some key areas as opposed to the whole thing where should I do it?
  7. crazyhole812
    Jul 6, 2005
    228
    missouri
    i think right by the back of the cab is the highest load area. so maybe under the cab and back past the rear spring hangers
  8. reptilianman
    Apr 9, 2006
    12
    Hey thanks for the replies guys,i dont have a cage at all ,that had crossed my mind and i'm gonna fab one of those in with boxing in the frame ,I took a trip out west and bent it up out there,it bent on the right frame rail undernieth the cab pushing it up about 2 in,? i know kinda stange, it got a little to high in the air (not that i even planed on getting off the ground at all) and it came down on the right side of the front bumper so for now i trimed the body lift mounts to level the cab,so the bodys straight agin but on the bent frame theres nothing in clarkston to bend a frame on unless you run over all the traffic here.lol does anyone have a long bed frame in or near Mi.so i could get this progect off the ground ....i mean keep it on the ground. thanks
  9. reptilianman
    Apr 9, 2006
    12
    Hey 73 i see your in goodrich ,do you ever go wheeling behind the junk yard on m-15 in davison?
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'm a little tall to fit in my frame... let alone with boxing gloves on... [drums] dun dun cha [/drums]
