Boyce Equipment!?!?!?!
Discussion in 'The Garage' started by firefighter184, Mar 27, 2006.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    $1300 for a freakin 14bolt? Did Jenna Jameson sit on each one or what?
  2. stewburban
    stewburban Registered Member
    Mar 25, 2006
    10
    new york
    try auction sights
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I'd pay to see that happen and then keep the 14 bolt.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Depends on what is on it. I am going to have to take mine out, clean it up, move the spring pads, get a disc conversion and brakes make all of that work, and I am lucky because mine has a detroit and 4.56'd in it already. If I had paid $200 and still had to do all of that it may start to look better at that price.
  5. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I told you so:wink1:
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i still need to find a freakin avn width
  7. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i paid
    150 for the axle
    about 600 for detroit and 4.56's
    about 150 for all the disc brake parts
    and had to cut off and remount the spring peaches and shock mounts plus the clean up on the greasy rusty old alxe
    plus all the small stuff that adds up
    i think it ended up costing me about 1000 all together
    so i guess its not that bad figureing in labor
    that is if thats 1300 for disc brakes and locker with it
  8. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    It is still to high because you can find 14 bolts out of the m1008 trucks with a detriot locker and 4.56 gears for around 200 bucks.
  9. cbbr
    Jul 17, 2004
    14,681
    I'll let you know if its too high after I finish mine....
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    14 bolt - free
    5.13s $199
    Master install $100
    welded spiders-free
    disk brakes:
    brakets $65
    rotors $60
    callilpers $33
    pads $20
    brake lines $40
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    It cost a Chevy dealership $2400 to rebuild a 14 bolt that exploded under one of the dump trucks at my old job. The only part they re-used was the housing. New gears, new gov-lock, axleshafts, brakes, bearings, seals. So it really isn't that bad.
  12. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,622
    612
    Hooper, Utah 84315
    $1300 is not bad he spent $517 wth no locker or labor add labor and locker and thats going to be the cost or really close.
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    She lives in Scottsdale AZ , and she only sits on 12 bolts :wink1:
  14. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    :haha: :haha: ....... Like me.... she has a soft spot for 1/2 ton axles...!
    Marv
  15. jaysonsk5
    jaysonsk5 1/2 ton status
    Aug 11, 2005
    229
    eastern iowa
    i got my 14 off a mud bogger for $100, it had 5.13 and was welded. but i had to get the brake parts, it is just the stock drum set up. i'd say i got less than $250 in it.
  16. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Who knew? I'da thought she'd go for the bigger type shafts.
  17. jaysonsk5
    Aug 11, 2005
    229
    eastern iowa
    :haha: :haha: :haha: you would think:eek1:
  18. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yeah, but he welded his rear so there is no need for a locker. And most of us on here will probably do our own installs (except maybe ring and pinion) so labor is free. anyways heres what i paid for mine:
    14ff, 4.56 gears, detroit locker, brand new in a crate and still had the factory gear marking compound on the gears: $550.:wink1:
    -Harrison
