bracket thing-ama-bobber on top of pumpkin??
Discussion in 'The Garage' started by 90blzr, Jul 9, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Looking under my cousins '87 suburban last night and saw a braket coming off the top of the rear axle on the pumpkin. It swivels and it appears it is hooked directly above to a bracket on the frame where two, what appear to be brakelines hook into...
    Anyone know what this is? I've never noticed it before!
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    just a bracket that keeps the brakelines tucked up near the frame. I think it also holds the block that the two brakes connect into.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Its a height sensing proportioning valve. When you add weight to the rear of the vehicle it allows more fluid to flow to the rear brakes. When empty it keeps them from locking up.
    John
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    no, this is different zakk, this is a big arm thats about a foot long or so...
  5. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Yup thats sounds like it!! Never noticed anything having it before! Do all Suburbans have them? Do the trucks have them too? I know my Blazer doesnt.
    Does it actually work? /forums/images/graemlins/confused.gif Sounds like it would /forums/images/graemlins/thumb.gif
  6. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Some trucks came with them some didnt. Dont know what years it started what had to be ordered to get it etc...
    I saw an 86 burb that had one. I've seen a couple of p/u's with them too, never on a blazer yet...
    They are supposed to work, but with GM things can go bad after awhile. When it does work it helps alot.
    My .02
    John
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mychal, what John said holds true. Almost all of the 3/4 tons from somewhere around '81 on up have them and almost all the 1 tons have them too. When I say "almost", I've seen more of them having these setups and a few have not because the owners have taken them off to get rid of them. They can be a "pro and con" thing. I don't use them because you can only lift the truck so high before the bracket is fully extended and sending the wrong signals for the braking. You can keep the setup by fabbing a longer bracket to compensate for the lift.
    My '85 K30 used to have it but the PO removed when he installed the lift. The '88 V30 in the yard does not have it as I think Bruce (Batmanjr) may have removed it. I'm not planning to reuse it. Just one less headache out of the way. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
