bracketry questions...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Feb 15, 2002.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    When going from a small block to a big block, its my understanding that all the accessories will work but the big block requires different mounting bracketry. Where is a good source for this stuff?
  2. gotmilkgotlift
    gotmilkgotlift Registered Member
    Jan 5, 2002
    16
    new england
    im in the middle of the same project, i was told to go to a speed shop for frame mounts, because the junkyards wont sell them most of the time
  3. a87ss305
    a87ss305 Registered Member
    Apr 25, 2001
    50
    Clear Lake, Iowa
    If you want to do the swap correctly you need to go directly to GM for the BBC frame mounts and the cup mounts that bolt to the engine. The rubber mounts you can get at your local parts store. Contrary to what some people will try to tell you BBC mounts are different that SBC.
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Do you have part numbers for the brackets and mounts you speak of? I know that 2WD trucks use different mounts for the BBC, but my research with GM and experience with this swap has shown that the mounts for the 4WD truck are the same for SBC and BBC.
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>'73 GMC Suburban - 502DFI</a>
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    In 4WD GM trucks, I've replaced a diesel with a SBC and an SBC with a BBC. In every case, I've just dropped the new motor in on the old mounts. The only brackets that need to be changed are the accessory brackets. Looks like that is what you are asking. If so, most junkyards are more than happy to sell the brackets. Try to find an engine with everything complete and in place so you can get the bolts and spacers (and know where they go, that can be confusing) all at once to save money and frustration.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
