Brain DEAD, I need some Pinion angle help?
Discussion in 'The Garage' started by TK5, May 31, 2003.
  1. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I know this has been covered over and over, but I'll give it a try.
    I got the 14 FF mocked up under the blazer. My floor isn't exactly level. I took my degree gauge and placed on the rear of the transfer case and got 5 degrees up or not level ( I have the transfer case dropped 1 inch). I've got the 14 FF placed on the level side of the rear. How many degrees up or down do I need on the pinion angle?
    I know this is a simple answer, but I am brain dead right now trying to get this rear in the blazer. Any help would be greatly appreciated.
    Thanks. Going to home to think about it. Work on it some more tomorrow.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I know Shaggy answered this a few days ago and I can't rightly remember, but I think he said everything needs to be within 2 degrees of each other.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
  4. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    If you aren't running a CV driveline then the pinion needs to be within 2 degrees of the T-case output. If it is a CV then it needs to be the same angle as the DL. Hope this helps you out, there is nothing like a DL vibe to piss you off.
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If your t-case sits 5 degrees down from the floor and your running a straight shaft (not CV) then your pinion should be placed 5 degrees up from the floor to have them running parallel. You would then want to point the pinion down 1 to 2 degrees to preload the pinion down so it will rise up equal unde load (axle wrap). It much easier to take measurements off of the shaft as it will make a straight line between the two to reference your angles from. Trying to take the floor as reference for the pinion is much more difficult.
    Tech Article:
    http://www.echobit.com/cgi-bin/echobit/tipstrickstech-public.cgi?tipstrickstech=3
  6. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Thanks guys, after a couple hours break and a t-bone steak it's starting to make sense to me. Sometimes it's best to just lay things down and walk away just to get your head screwed on straight again.
    It is a straight shaft. I guess the spring degree wheel was playing with my head. I guess I need to pick up one those fancy plastic ones from Home Depot.
    Thanks again.
