brain food, different diff axle ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arq, Jan 17, 2002.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    what size tires would I have to use if I run an axle ratio of 3.73 on back and a 4.11 in front, or vise-versa. I am not saying that I would do it just seemed like an interesting question to ask.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    myabe 32s in the front 35s in the back...
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    close but that could work.
    3.73 w/32s
    4.11 w/35.3s
    this is what I found
    3.73 w/33s
    4.11 w/ 36.4
    remember though these would have to be actual(true) tire sizes.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hmmm... ARQ I think you need to GET OUT OF THE SUN!!!!!
    hehehe
    I wouldn't try to compensate for the ratio differences by changing tire size. It 'may' work but do you realy want to try??
    Slip Bang POP Crunch Snap PING............Damit I should have just match my gearsets.......[​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Tire size is irrelevant.
    Oh, you mean and in 4WD?!? Why would you wanna...
    Seems to me the smaller gears would need more torque. So one set of tires would be eating your engine's torque versus spreading it equally between the 4. I do believe they do this in some swamp buggies to get more tire spin on the front helping to float the heavier front better while still providing deep grabbing traction for the rear. But I don't know for sure.
    My calcs say that 44s with the 3.73s would work with 40s on the 4.11s. Why not just go with 3.08s in the rear with 44s and 4.56 up front with 30s! Now THAT would look cool! [​IMG]
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    WOW! Talk about the "stinkbug" look!!!! [​IMG]
    That would be like a "real-life" Ed Roth RATFINK drawing....
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    No, that's backwards. The bigger tires should go with the lower (higher number) gears. With that setup, you would have to run two spares, but maybe you could store the 30 inside the 44!
    How about just using the same tires all around with two different gear ratios, but use a 203 transfer case and just never put it in lock? It would last a little while...
    Or use a 205 case, but get a different gearset to transfer the power to the front so that it compensates for the difference in axle ratios.
    I actually always thought it would be cool to have a transfer case with 3 speeds: 1:1, 1:1.4 and 1:3. Then you would just keep your stock axle gears and use the 1:1.4 range as though you had swapped in 2-3 steps lower in the axles, use the 1:1 instead of having an OD transmission and 1:3 as a great low range. But you would want to be able to select the reduction seperate from 2WD/4WD. And of course, it would put more stress on the driveline than a real gear swap.
    <font color=green>Today's Forecast: Partly cloudy with a chance of mud</font color=green>
  8. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I have read in mags about a group of 4x4ers in Florida that run bigger tires in the rear and smaller ones up front and make up the difference in gears. They love it apparently. I also have heard of the serious mud boggers (rails) running a setup like this. The reason was the smaller tires offer better steering when you're flying accross the mud.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    every 4x4 tractor that has big n littles does it.
    it is easy to do the math.
    31.7?? w 3.73
    and
    35 w 4.11
    i have an exel spread sheet for side by side gear ratio comparo
    formerly 77chev
    still a jerk though
