Brainstorming on manuals
Discussion in 'The Garage' started by neverendingproject, Mar 26, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    As the name states, and my continuing quest to make the blazer a neverendingproject, I've thought of something.
    Im wanting to do a manual swap, and heres the problem.
    1. I need a tranny with a 32 spline output. (could get adapters)
    2. It need to bolt up to my SBC (could get adapters)
    3. I would like 6 speed but would do with 5
    4. My 383 is balanced. How to I change it to a flywheel from a flexplate without having to balance the entire rotating assymbly?
    So, brotherhood. What are my options?
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I know most of the SM465 is a 32 spline output that will obviously bolt to a sbc, but it is a 4 speed. I'm not sure what the output is on the NV4500, but it an option.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    nv 4500 os 32 spline, thats a 5 speed tranny. sm465's are almost all 10 spline (at least the ones you can find) i was lucky enough to get a 32 spline 465/ 205 combo. Uve heard real bad things about the nv5600 6 speed and that wouldnt be a direct swap like the 4500 would be. the 4500 has a granny low the first 2 years it was produced. id get a early model 4500 rebuild it and fix the fifth gear issue.
  4. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    ya thay have big parts and life problems with the 5600s and neat little info the 2x4 gm fixed yokes dont have the 5th gear nut problem as all the rest. its a sandwich with the yoke nut holding it all on. i am using one with a divorced 205 my self.
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    So I guess I will have to find a 4500 huh?
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    thats what id do if i were you. 4500 either 2wd and divorced or 4wd and redrill a 203 for a doubler or slap on a 32 spline 205
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    A lot of the GM 4wd version NV4500's have a vibration dampner between 5th gear and the nut...which isolates the nut just like the yoke on a 2wd version would. The nut is only a big deal to swap if you tow very heavy loads and or have major input torque (CTD or 6.5TD)
    Rene
  8. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I can get a 2wd dodge unit for next to nothing. How hard would it be to change the output shaft and take off the tail housing to work, or is it not that simple?
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    It's not just an output shaft, it's the entire mainshaft. Easier to go with a divorced set-up IMO.
    Rene
  10. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I dont think that my blazer will like the divorced setup. Im going with a 241 anyways.
  11. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Also, anyone have input on the engine situtaion, and what do I do about the stroker?
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I think all you would have to do is have a flywheel balanced to match the flexplate, and make sure the crank is drilled for a pilot bushing.
  13. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Is that like the 1 inch hole in the back of the crank?
  14. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    that's the one.
  15. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    So what about this. New bell hosing, mainshaft, output swapped into the dodge case? I think it would still be cheaper than finding a gm one or buying one.
  16. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Need an output housing as well, and if it has the larger (1 3/8"?) dodge input you'll need to swap the GM 1 1/8" inout shaft as well.
    Rene
  17. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    This would still be cheaper, yes?
    Im having a hard time finding technical info on the 4500. All I find is places selling whole parts or stricktly dodge stuff.
  18. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
  19. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I talked to the guy and he said I need to replace the input shaft, front bearing retainer, output shaft, fifth gear, fifth gear nut, and tailshaft housing. I will also need either the GM fifth gear spacer or damper.
    Geez, I hope its cheaper
  20. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I completely rebuilt mine, including new input shaft/gear, new countershaft, 3/4 synchro hub, 3/4 synchro rings, 5th gear synchro ring, 5th gear synchro hub, new nut, all new bearings, all new seals, small parts kit for just under $900 US.
    My 4500 was free to me as a basket case though, so still worth it and I know exactly what it's condition is.
    With the new bellhousing I'll be into it for about $1300 US.
    I saw an NV4500 in the for sale forum for $1600 obo...including bell and shifter.
    I think you'll need to get that tranny pretty much for free to be worth it, and even then it'll be close.
    Rene
