Brake bleeding/flushing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, May 14, 2000.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I need to replace my calipers and cylinders, and I'll probably do the flex lines too. Should I flush the system first (getting all crap out), then replace parts, or do parts then flush? Flush from the master cyl. down or from bleeders up? I'm thinking of getting one of those Phoenix Injector things; anyone have any experience with one? Thanks.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    DO MY BRAKES ONCE EVERY TWO YEARS, I USE A MITY-VAC THESE CAN BE BOUGHT ALMOST AT NY AUTO PARTS STORE, BUT I THINK J.C. WHIITTNEY WAS THE CHEAPEST? SEEMS TO WORK PRETTY GOOD.
    ALSO I WOULD REPLACE THE THREE HOSES WHILE YOU ARE AT IT.
    SINCE YOU HAVE TOO BLEED THE LINE ANYWAY I WOULD NOT FLUSH FIRST. GOOD LUCK!
